newworld666
This whole Cradle to Grave as a test track for clipping needs to die because it's really a user case error than the gear where the user has no idea where to set the volume and is treating bg music with 30hz and 60hz like it's 50 cent in da club. I don't get this macho thing that's on the road to hearing loss. The only torture test are broken gear and ears...which is probably how Passion for Sound got ruined Stealths coz of the owner trying to clip Cradle to Grave.
As a challenge, listen to Cradle to Grave at the volume you are whining there's not enough power then play Mozart's complete wind music's track 3. Both have the relatively same DR and peak. Actually the wind album has lower peaks so you can listen 1.5dB louder. lets see if u can handle being that up close to the wind instruments as much as the bass notes.
Cradle to grave
Mozart first 6 tracks
I could notice that clipping and distortion in low and ultra low frequencies are not really linked to a volume level or even dynamic.. but probably much more concerned with some instant juice available with low impedance headphones and not really sensitive like the Stealth for low and ultra low frequencies (though I get same issue with the HEDDphone one too which is 42ohms and not 23ohms) ...
Cradle to The Grave is just an extreme track with almost little dynamic but amazing strong and rather low for ultra low frequencies (probably between 15 to 50hz).
I have many genre that are sometimes concerned with such clipping or distortion like Electronic, Drum&Bass, Trip-Hop, R&B, Rap, Jazz .. it's almost never concerned with acoustic instruments...
It's maybe less than 10% of music I listen... so, in real life, it's probably not a big deal to have such limit for many.
