ra990
I don't know about this... I think Dan has mentioned previously that the AMTS actually makes EQ more effective. Of course, your warning about pushing the low end way beyond it's limits is valid. As long as you're not detecting any distortion with your EQ, I think it should be perfectly fine. Although, what I like about the DCA Stealth is that they're tuned so perfectly that EQ is not needed at all, imo.I wouldn't do that if I was you, you don't want to make the drivers try and produce a signature they were not designed to.
Check with the manufacturer if its safe for you to boost the low end to match your bassy headphones on the bass department.
