Dec 26, 2024 at 1:44 PM Post #2,566 of 2,787
Dec 26, 2024 at 1:49 PM Post #2,567 of 2,787
Dec 26, 2024 at 1:52 PM Post #2,568 of 2,787
I can’t understand 1.5A correlated to output power, can some one chim in
In my experience,
Liric II is said to be easier to drive, but with FiiO BTR15, I need to turn it up all the way to 100% and I think it is not quite there.
BTR15 rated 340mw @32ohm.
If it can’t drive Liric 2 to satisfied level, it can’t driver E3.
Dec 26, 2024 at 3:35 PM Post #2,571 of 2,787
Good info, thanks! Questyle looks like a good option.
It appears that other than the xlr option, the dca 4.4mm Vivo cable is also a balanced cable option, if I’m not mistaken
If that’s correct, if that’s true, it seems better to get the 4.4mm option so to be able to use them with a balanced portable amp.
And then just get a simple 4.4m to 1/4 cable adapter for use in the studio with 1/4 amp options there.
If that makes sense..
Dec 26, 2024 at 3:42 PM Post #2,572 of 2,787
This makes sense for sure, however I found the Vivo cable too bright and a bit harsh on trebles, I replace the cable by a Forza Audio works noir which give a better sound with better bass well extended and smooth the high frequencies very aggressive from 3 kHz
Dec 26, 2024 at 3:46 PM Post #2,573 of 2,787
When I search for closed back headphones, the E3 comes up again and again as possibly the best one bar none. However, I’m concerned about comments that the positioning affects the sound. Dan mentions it almost as a feature, but I’m not so sure. Anyone have issues with positioning? I can’t imagine having to worry about having to maintain the headphone in the same position on my head at all times.
Dec 26, 2024 at 3:51 PM Post #2,574 of 2,787
Ahh.. more money 🥴 ..may not be an option when considering the E3 + a port amp solution.
Dec 26, 2024 at 3:54 PM Post #2,575 of 2,787
I tried different positions for them when I first got them to try and tame the shoutiness and didn’t find it changed the sound for me. After a day of listening the shoutiness disappeared though. It may vary from person to person.
Dec 26, 2024 at 7:15 PM Post #2,576 of 2,787
Thanks for the answer. Would you say that it’s like any other pair of headphones in that regard?
Dec 28, 2024 at 9:13 AM Post #2,578 of 2,787
dang so many midish tier dap choices out there, who's got the time?!
In case this worm hole help others as well...
Mojo 2,
Cayin N3 Ultra,
Astell&Kern SR35,
Onyx,
G5,
DX240
Queststyle,
…& Even more budgeted options,
Qudelix t71,
ifi.....
However, if anyone has insight on good e3 symbiosis re; audio "mixing / critical mix eval" on the go, please chime in.
Engaging but not slanted eq presentation is the goal.
Jan 4, 2025 at 12:15 PM Post #2,579 of 2,787
Generally because of ear anatomy the headphone for most users will pick up some 3K emphasis as you move the headphone back on the head. It’s pretty predictable for most users, so if you want a little more lively upper midranges you keep your ears centered in the pads and if you want it a little stepped down, you move the headphone a bit down and forward. I do actually consider this a feature in that this is a region that varies based on your individual ear, which may or may not resemble the ears on measurement rigs. Some ears will have more 3K gain than the measurement setup, some less, so this gives a degree of control over this region that otherwise is rather random. Is it a feature? Not quite. But it is, IMHO, a benefit. I am a :wink:
Dan Clark Audio Make every day a fun day filled with music and friendship! Stay updated on Dan Clark Audio at their sponsor profile on Head-Fi.
@funCANS MrSpeakers https://danclarkaudio.com info@danclarkaudio.com
