Damping Mechanical Energy Distortion of STAX and other phones with SORBOTHANE and other materials.
Aug 4, 2017 at 6:46 PM Post #856 of 952
Truthfully, if one takes care to acoustically decouple the cups from the headband the problem becomes a non issue at the source.
i think that you are right.... sorb. taped on the headband will reduce crosstalk greatly.... But i think that the point of our new creative friend Mogimu is precisely demonstrate the great extent at which crosstalk affect the perception of music... and i think that his experiment is very interesting....
Aug 4, 2017 at 6:51 PM Post #857 of 952
Cross-talk between the earcup drivers is being recognized as an important issue for headphones. Going back a few pages, I referred to Mitchell's measurements of this. He also noted that with some wiring setups you can get electrical cross talk as well. See p26 of http://www.politicalavenue.com/108642/US-MAGAZINES/Hi-Fi News - July 2016.pdf in HiFi News and Record Review. I assume that electrical crossfeed is worst with common ground wiring found in most dynamic phones, but not Stax electrostatics, which use separate grounds for each channel. Sennheisser uses its mechanical damping material solely in the headband of the HD 800, according to their advertising. I see that their new and hyper expensive H1 uses a large swath of padding under its headband, which I assume also mechanically dampens the headband to prevent mechanical crosstalk. Similarly there is one set of B& W and Audioquest phones that specify that their use of damping in the earcups addresses the crosstalk problem. I think they are missing part of the issue though which is that mechanical vibrations will affect the same side earcup even if there is no headband. Thus I have found very large improvements of the sound of earbuds and IEMs by adding sorbothane damping and these of course have no headband at all
You raise the question about crosstalk through bone conduction in the skull. Certainly hearing can take place, skipping the ear and directly stimulating the the skull .or jawbone There are hearing aids designed to be used by bone conduction for people who get limited benefit from conventional hearing aids. There are also a number of sports headphones which some people like because they keep drivers from blocking the ear.
I would think that if the hard surface of the headband touches the skull you could indeed get bone conducted crossfeed. However padding should stop most transmission to the skull. But as I noted in this thread only some kinds of padding will reduce mechanical vibrations to the same-side earcup or create crossfeed to the opposite earcup through the headband. So far my experiments say high density (i.e. 70 duro) thick ( 1/4 to 1/2 inch) sorbothane applied with self-stick tape or better glues such as the Lord line are the most effective.
thanks for the link, I found the thinking and process even more interesting than the test itself. I started reading this and looking at the measurements thinking the dude was on drug. I've never come remotely close to measure that sort of electrical crosstalk in my headphone even trying some really weird IEM cables on it. but then I turned on my second brain cell for a change and noticed how he went for a series of low impedance headphones(why?). that of course changes everything. the amp used here has a 100% chance of outputting worst crosstalk when plugged into a low impedance load. and same for the cable with relatively significant current flow in the circuit.
still if there is no big flaw in his testing, the vibrations do seem to be high enough to kind of matter (I tend to disregard crosstalk below -40dB because that's where I start to fail noticing it in an ABX). I expected this to happen but not to reach such magnitudes TBH. so now I admit I'm curious. and as I always end up picking comfy and light over good sound, it should greatly increases my chances of having vibration issues, I will add fooling around on this matter to my to-dio list.
Aug 7, 2017 at 7:02 PM Post #858 of 952
I really can't follow what you are doing here. I realize it is hard to present photos with the new Head-fi set-up, but these might make it clearer. As regard the problem of transfer of mechanical energy from a headband to the skull, why not just put the tape on the headband or other part of the phones that comes in contact with the skull. This would seem a lot easier to do. In practice I would have thought that just about any foam padding would be enough to block transmission to the skull.
I should compare the Ta 102 tape with sorbothane using my Stax SRXIII set-up. This has previously allowed me to determine what thickness and duro to use as well as the effects of different glues. I have several outer covers for these phones and can compare different damping materials by swapping the outer covers around a process which takes about 90 seconds. The Ta 102 seems rather expensive compared to similar sorbothane. Anyone care to send me 2 strips about 4" by 1/2"?
Hi Ed - I will tke a look at the process involved in posting photos here in the near future. Meanwhile, in answer to your question about the point of my skull experiment : it is just an experiment, not a solution. I wanted to see if any significant vibrational energy is being transferred to the skull via the headband, even though the headband is already completely treated with fo.Q tape. My results suggest that it is, and that the sound is audibly improved by any measures taken to absorb vibrational energy between phones and skull, and even in the skull itself. Headphones are a special category of listening device because they make contact with your head, unlike speakers. They may require a new approach to vibration control.
I chose to use fo.Q tape rather than foam padding because of its ability to convert vibrational energy into heat. Foam would merely reflect the unwanted vibrations back into the headband, making the smearing and crosstalk worse throughout the entire headphone structure.
If you send me your mailing address via PM, I will send you the fo.Q tape samples you requested. I notice that you have been generous enough to have done the same for others earlier in this topic.
Aug 7, 2017 at 7:17 PM Post #859 of 952
It may be very difficult to achieve complete acoustic decoupling of the headphones and headband. For example, Audeze LCD-3 phones appear to be reasonably adequately decoupled, with the use of a single screw to attach each earcup to the headband. However the headband still transfers significant vibrational energy into the skull resulting in audible distorion, which can be controlled to some extent with the use of specialized damping materials.
It's also important to remember that headphones and head are acoustically and mechanically coupled, and that vibrational energy transfer is a two-way process.
Aug 7, 2017 at 7:28 PM Post #860 of 952
Not the case. I have yet to see any phone that actually takes reasonable care to decouple the cups from the headband. Pet peeve of mine. Single screw or whatever if you take a few SECONDS of your time and a piece of metal tubing to make sorbo grommets for the cup attachments on any phone you will see a vast improvement. It is not much different from motor mounts in an automobile. Yet even the mightiest of manu's with their 5K a pop phones do not condecend to do this for the end user.
This aint rocket science it is simple vibration decoupling which has been around since the middle ages. We have better materials now and yet we accept less than medieval technology for outrageous prices.
Putting damping materials on a headband itself is nothing more than putting on a condom after you have had sex.
Aug 7, 2017 at 7:38 PM Post #861 of 952
That's a great idea and I will try it. As I said in an earlier post, I have only become aware of the importance of the headband issue over the past couple of weeks. I don't see the point of your condom analogy though, since fo.Q tape on the headband actually works.
Aug 10, 2017 at 12:06 AM Post #862 of 952
I.i.
As I recall Mitchell's article ( the link has died) he was responding to a criticism of an earlier report that electrical crosstalk may have contaminated his measurements. I have emailed him a few times and he has been very helpful. Among other things he advised me to try constrained damping, i.e. backing the damping material with something, in my case a two layers of electrical tape. It improves the effectiveness of the damping material.
Aug 10, 2017 at 1:33 AM Post #863 of 952
[QUOT
I would suspect that if you put enough force on a sorbothane gromet to give you effective clamping of the earcups to the ear, the gromet would become compressed enough to act like a solid object and still transmit vibrations. I am not stating this as a fact but it would seem to be one of those things that you try and see how it works.
Certainly Stax blew it with their SR007 by creating a headband of two metal strips and screwing them directly to the metal earcups.
Even if you get rid of mechanical crosstalk, this is only part of the problem as you still have the degrading effect of the vibrations in the same-side earcup. One of my more interesting experiments was damping cheap earbuds which of course have no headband and yet still improved greatly with added sorbothane.
Aug 10, 2017 at 8:22 AM Post #864 of 952
[QUOT
My initial thoughts exactly. My experiments with a rudimentary grommet for the LCD-3 seem to confirm it. The fo.Q tape on the headband works much, much better, and is still effective with or without the grommet.
Aug 21, 2017 at 11:58 PM Post #865 of 952
I picked up a catalog and saw,"constrained layer damping" being advertised in a new Mobile Fidelity. turntable. You may recall that Keith Mitchell advised me to do that with sorbothane. What is it?
"Constrained-layer damping is a mechanical engineering technique for suppression of vibration. Typically a viscoelastic or other damping material, is sandwiched between two sheets of stiff materials that lack sufficient damping by themselves.
Constrained-layer damping - Wikipedia
Recall that sorbothane is a viscoelastic.
For me constrained layer damping meant backing the sorb with two layers of electrical tape.
Upon Googling the term further I see two speaker companies adding this to their speakers, ATC and KEF.
This is big news, speaker manufacturers are adding constrained layer damping materials to their speakers, i.e. sorbothane or similar materials. I have been doing this for a while, I especially like 1/2 inch sorbothane on the front panel. Here is a KEF advert. https://microwire.info/kef-ls50-wireless-complete-fully-active-system-singapore/
Aug 28, 2017 at 12:47 PM Post #868 of 952
Re: Sonus Faber: "The suspension system permits inhibiting the mechanical transmission of vibrations to the environment and consequently eliminates the creation of spurious resonance and sound feedback."
However it also uses vico-elastic (i.e. sorbothane or similar materials) in the cabinet.
"The double walls in okoume plywood with dual curvature are uncoupled by a “constriction damped” visco-insulating layer. The dual curvature increases rigidity compared to techniques used in the past, while the dampening eliminates the last traces of resonance."
So they are using a double dose of damping techniques. " Constriction damped" sounds like "constrained layer damping."
Sep 8, 2017 at 1:12 AM Post #869 of 952
I came across another speaker manufacturer using " constrained layer damping." This is Epos and the discussion relates to their ST 15 speaker.
http://www.epos-loudspeakers.com/support/what-is-constrained-layer-damping/
Like most such reports they don't identify the damping material itself although they state that it is not specifically designed for this use. Probably they want to keep this information as a proprietary secret to give an advantage over competitors. Unlike most such reports they actually give some measurements of the vibrational damping they achieve. Unfortunately I can't open their pictures.
Quite some pages back I reported that putting backing onto sorbothane gave better results than unbacked sorb and I use backing on all my systems now. However I am simply using a double layer of electrical tape for backing. I compared tape vs metal clips on the headbands of Stax Lambdas and heard no advantage for the metal. However I would not say that is definitive rather it is merely some data points on a complex problem.
If you google this issue you will come across various mechanical engineering studies. This pdf looked helpful.
https://factorydaily.com/fdattachs/fdattachs6/112616243210798.pdf
Sep 9, 2017 at 12:08 AM Post #870 of 952
ok, I'm tired of searching, and I think the answer is actually in a T50rp thread, and was never asked or answered in this thread.
For sorbothane that doesn't come with self-adhesive, which side goes down? Shiny side? Or dull side?
