richard51
- Jul 21, 2013
Just in case anyone has viewed your link to the Spanish Fo.Q review, I would like to point out that the link shows TA-102 tape which is generally too thick for headphones except perhaps for use internally. The thin tape TA-32 is much better all-round and it is the one to get. Also as I said, if you buy from some Japanese sellers on eBay, you should be able to get some TA-32 for around $35 and very low postage. I have purchased about 10 packs already, for various uses. I'm still waiting for some of the packs to arrive.
i have found that the tape works well on all the headphones I have tested, particularly Audeze LCD-3. They were the first high-end phones I purchased, but I was very disappointed with their dark, almost muffled top-end. After I bought 2 other high quality phones, I decided to use some techniques which I have used on other audio gear such as amps and speakers, to see if the LCD-3s could be improved. After all, I was not using them at all any more. One of the techniques was to apply fo.Q tape internally and externally. I can report that LCD-3s can be vastly improved with the application of fo.Q tape, and completely transformed by using another technique which I don't want to suggest just yet. The reason I won't suggest it now is because it could result in damage to your headphones if you are not extremely careful. I will keep that suggestion until readers are ready to try something even more amazing than fo.Q. I don't want to be blamed for any disasters after only a few posts on Head-fi, haha.
With the fo.Q tape, it works amazingly well on the arms which join the headphone cups to the headband. Also all around the inside of the front baffle underneath the foam pads. Also all around the back of the headphones, underneath the back plate. You don't even see it in those locations, but you sure can hear it! I can't compare it to Sorbothane because I have not tried it. It's fair to say that Sorbothane is optimised for shock reduction, whereas fo.Q is optimised for molecular level vibration reduction.
I must wait to buy them before a month(budget limitations) but i plan to try the Ta-102 glued on the exterior cups of my beyerdynamic DT-150,rather than inside where is the sorbothane, i think the 2 will complement one another, on the exterior the thickness will not cause problem... Perhaps the thin TA-32 woul be better? I want to buy the TA-102 because i plan to use the rest on an amplifier and thicker is surely better there than thinner....what do you think?
