Tjj226 Angel
- Oct 20, 2012
What even is this thread?
If we are comparing cheap delta sigma to expensive delta sigma, then you shouldn't hear a difference. 99% of the dacs on the market these days use one or two ICs for the entire dac. The only real job the designer has to do is make a high quality DC power supply and design a clean PCB layout. In other words, all the designer has to do is not screw up.
Years ago, Dac ICs were far less sophisticated and you had to design your own filter, output stage, and so on. In those cases, yes, dacs could sound very different from one and other because they were physically different circuits. These days most DAC ICs pretty much do everything for you, and the technology has become so precise that the difference between a high quality sabre dac and a high quality AKM dac is pretty much indistinguishable.
If you are comparing a good quality delta sigma dac to a different dac architecture (r2r, fpga, and so on), then the comparison should be made on a case by case basis.
