I had considered buying some DT770's for many years but always ended up with alternatives. However, when I discovered Custom Cans sold them new, with their balanced conversion, I jumped in , with excellent results.
This means, I am unable to give you any advice re: possible sound changes, having never owned the stock cans. The only thing I can say is the workmanship seems of a high standard.
Good luck with your decision making!
the whole cable thing can be incredibly subjective - see sound science forum for examples - you will have to decide for yourself here as the spectrum of opinions and evidence is very wide.
Was going to mod my existing beyer dt770 80ohm's - but after listening to them, compared to my AT's and thinking about them further I was worried about one of the drivers rattling a bit, then sending them in, the extra costs etc. So talked myself into buying a new set to compare to the old set... The 80ohm's can move to piano duties anyway.
Went for the 250ohms this time. : 'Custom Cans Uber Beyerdynamic DT770 250ohm headphones with modified drivers and detachable balanced litz cable (Desert Camo), Balanced Connection 4.4mm TRRRS'
initial rinsing of the new grey code - renewal album (prima, voyage XIII and Illiad especially)
- deep throbbing bass, sub bass
- I can feel my eardrums oscillating :-D
- closed obviously and feel like you are super deep in the tunes
- a bit heavier than my non-modded 80ohms - as there is additional damping onboard
- lovely stuff
Last year I had a detachable mod done to my old Grado GS1000i headphones. I also ordered a dual 2.5mm SE cable for them, and a SE cable for my Sennheiser HD650 as the cheap ebay cable for them had broken months prior.
Not having comparisons for the cables, I thought them both serviceable but nothing amazing, but maybe I was sleeping on them!
One issue - the right Sennheiser connector was not quite flush and the right channel would cut out occasionally - that cable was commandeered by Mum for her 58X (where it works flawlessly), so not a huge deal there, just worth mentioning.
The actual Grado mod is quite well done - they must have had to unglue the earcup grilles and do some intricate soldering.
After reading about their cables I may have to order some more, balanced this time, and put them up against my Periapts!
I have been designing a couple of new ranges of cables and am very excited to be in the final testing phase for the higher end cables. The aim has been to create a bit of a statement piece that not only had a higher speck than our current range but also be a thing of great beauty ( I know that is subjective ). We worked with a UK company that makes embroidered silk to create the cover for us. The aim being to separate the cores as much as we sensibly could without making the cable too bulky and heavy. It is a nice crossover between art and engineering.
