beaniebaesha
ethereal sound I had a look at their line-up looks promising, they released alot of tech
thanks crinacle, but i wanted to know in little more detail why do you think trio is better than the flagship fourte and from your list it shows that u12t seems to be better than both trio and fourte how is that possible that a third or evern fourth ranking inear is able to be better than the flagship just curious, anyway I wanted to say your list is brilliant and I am only asking about 64 audio iems because I have not listened to them but for the rest of the iems I have had a listen ,your list is pretty accurate so thanks for your trained ears and hard-work
@crinacle between Sony M9, SD5 and PP8, which has the most detail retrieval? or is there one particular one that sticks out the most in your opinion.
i currently have a 1650 which i enjoy very much due to its energetic nature,
looking for something abit more similar to my ER4SR but not as "dead"
shortlisted FitEar Parterre but feedback seems like it excels for acoustic/classical most
cheers
@crinacle Will you be demoing the new AAW lineup? It seems quite promising
Hi,
Currently using Etymotic ER3XR's mainly for their sound isolation for when I am outside. My one complaint is that they sound a bit too bright (? not sure if that is the word). I just got word that the Massdrop Plus is back in stock and I am considering getting that instead. Would it be worth the upgrade?
I love the Sony mh 755, cheap and sounds great. I bought a cable extension to go with it. I found the mh 750 to be basey for meRe
You may also consider a MH750 which is a normal length iem that comes with a mic and is the free earphone that comes with the Sony Xperia smartphones while the MH755 is a super short IEM which comes with sony's bluetooth player.
MH750 is slightly different from MH755, there was a graph somewhere which says the MH750 has a bigger bass boost compared to the MH755.
There are 2 ways of getting the MH755.
1) Getting one of the sony bluetooth player and you can be 100% sure that it is genuine MH755.
2) Getting one from the resellers. From what I know, sony was making these in huge quantity. Therefore the only way to get them is in huge boxes like these:
More information from one of the sellers from taobao for the white MH755(selling at 20rmb):
1) These required burn in.
2) The white version is new old stock from 2013 ( I finally understood what the seller really meant after reading the sentence for a few more times)
3) One order can come in 10 thousand earphones, that's why the price is cheaper than cabbage. Super good price to performance ratio.
4) Really have to respect Sony's manufacturing and choice of raw material. These have been in the warehouse for 5 years, no yellowing and no stickyness.
5) BUT!! the black version of MH755 is very very rare, which is why i sell them at 80rmb. So whoever is selling lower than this, you should know (implying that it is fake)
6) One way to see if it is genuine/authentic, look at the date and serial number:
Authentic ones should have the same number at 3 places:
1) 13W36 (made in 2013 week 36)
2) the first 4 character of the serial number is 1336
3) there is another 1336 on the wrapping packages.
Disclaimer: I just try to translate what I see to share information for all those who are interested in the MH755. I am in no way related to the seller. Some of the information do seem fishy to me, but this is one of the top sellers for sony accessories in taobao.
I did order from taobao using taobao forwarding agent and the MH755 is on the way to me. I do also managed to find a used sony bluetooth player that comes with the black MH755 in my local marketplace(yet to receive them).
The price to sound relation could not be truer more expensive does not equal better, same with having hundreds of drivers does not equal to better sound, like I asked before crinacle what is that one iem that does it for where you can just sit down put the iems in and just float away, like the one iem or a few iems that really catch your eye, as your probably they few people that have actually listened to many iems, also another quick question regarding the comparison between the u12t and trio which would be all rounder which also focuses more on detail, clarity and nice soundstage and some nice body not too thin.
PP8 is the most resolving to my ears but also the driest. M9 is the middle ground of the three. If you want something not as "dead" as the ER4SR, avoid the PP8.
The UE website shows 18+ 3rd Gen, any significant differences in your opinion with 2nd Gen? ThanksThat IEM would be the UE18+ 2nd Gen for me.
sorry i noticed you described the EX800 as a warmer version of the EX1000,
by that do u mean that the EX800 retains the similar level of detail and imaging as the EX1000 but with a tad more of warmth?
thanks
Gotcha, thanks! I'll stay away from them...
Hey crinacle I also wanted to know your thoughts on the latest campfire solaris did it not live up to the hype as from your list its seems to be in a lower category compared to the likes of trio or u12t ,what was lacking in the iem, I personally think the midrange is very important so between the three which would have the strongest midrange and some general thoughts on the solaris as it was supposed to be like a budget totl compared to the current crazy prices of totl iems, the reason I brought up solaris was becuase I loved the andromeda but the fit was bad and then the solaris turned out to be even larger, I still dont want to spent tia fourte money tbh
