blah1234
- Dec 18, 2015
Did you guys ever figure out that you can create an OTG y cable for this, unlike the ones that are commonly sold which only support charging of the accessory. If not let me know.
Hey guys I just wanted to recommend and just wanted to confirm that if you plan on using the Sound Blaster E5 on the PS4 or Xbox One, you must set your Audio Settings to LPCM or Xbox one via (Stereo Uncompressed). I even spoke to a creative customer service representative for the E5. I even have the Chat Log
So you can use the Sound Blaster E5 via Optical / and Set your Audio Settings Through LPCM on the PS4 . It sounds awesome with the SBX and I really like the virtual surround that creative has given us for gaming. I was even able to adjust the surround sound via the SBX Pro and it sounds awesome. so if you plan to game on the PS4 or Xbox One I definitely recommend this product. Make Sure SBX is enabled on the E5
EDIT: You can also use your Creative Sound Blaster E5 with the Xbox One via Optical. Make sure you set your Audio Settings to Stereo Uncompressed, then enjoy your SBX Surround. Make sure the SBX is enabled on your Sound Blaster E5.
LPCM is Stereo Uncompressed
Hey there folks,
Wanted to note that in a few days we'll be posting a firmware update with a couple highly requested features rolled in.
1. We'll be adding 7.1 virtual surround support (similar to our G5 unit). This means the device will appear as a 7.1 device to your operating system and will utilize all channels for virtualization versus just the current stereo channels. You can switch between stereo or surround in the UI.
2. We're adding virtual surround for headphones over the line / optical output.
We're looking to have this out prior to Xmas..so keep an eye on the website.
@DigitalRonyn Please upgrade the EQ to 20 bands instead of 10 bands. And a way to stop The E5 charging android phone (or not shut off after charging the phone for only about 30min, the e5 still have like 75% battery left). And smaller volume steps.
That's definitely a must. We need a way to stop the E5 from charging android phones.
Btw, will future product support quick charge?
Panzerfan, the main difference between the E5 and G5 now is primarily the Bluetooth and "Portability" of the device.
The E5 is designed as a portable amp / dac first...so it has the battery included that will let you take it on the road and use it as a portable amp / dac with any smart device / phone, etc.
The G5 is designed as a portable sound card to be used VIA USB. So you don't have the Bluetooth capability or the internal battery.
I'll get a better breakdown of the two posted up here so it's a lot clearer where the differences are for everyone.
