Mindstorms
Formerly known as Midnstorms
- Oct 24, 2016
the change its fairly simple?
I'm using pulseaudio on top of alsa, but alsamixer shows all of the controls that matter (like gain settings).hello,
can someone that owns the E5 tell how does it show in alsamixer? does the spdif input and output show up there? thanks!
< Speaker >Speaker C PCM PCM PCM Captu PCM 1 PCM 1 Line In Line In Line In 1 Line In 1 Bluetooth Bluetooth Bluetooth External External External External Input Gai Input Gai Internal Internal Internal Internal S/PDIF In S/PDIF In S/PDIF In S/PDIF In What U He
Removing device in windows and installing it again, fixed the internal mic, will try with a different external mic.Hi,
I plugged a Maono au-400 microphone in, and now I have two problems.
1. The external microphone does not work, should it work?
2. I can no longer use the internal microphones
I tried to push power+volume 5 seconds to reset it, but it made no difference.
Anyone have some input on this?
Thanks in advance.
