TripBitShooter
- Mar 24, 2014
i think singapore already has it for sale, maybe cos singapore is creative's home country
i think its already available for preorder through the SG website
hey ClieOS, which one is better, an iFi audio iDSD nano or a fiio E18?
My friend is asking me for an android compatible USB DAC recommendation and does not wantt to wait for the creative E5
think i will suggest the FiiO E18. His SRH750DJ are known for being hard to drive, around here in Head fi.
P.S. I have been staring at pics of the iDSD for quite a while now, and i wonder how portable it can get. It seems really bulky
Yes, it is not exactly portable due to the blocky design.
Hiya everyone, iv got a question: I have a creative e1, can it be used as a usb dac on android phones through usb otg? I cant find any info on it or iv missed it. Basically iv tried it &although it does work I.e the sound comes out of my e1 when its connected to my galaxy note 3 via the otg cable but the e1 actually starts charging through the otg cable from my note 3? Or atleast I think it does? The led on the side of the e1 flashes white when it's connected via the otg cable & is switched on. If it switch the e1 off i get a solid white led (while connected via otg cable). What I do know is the battery drains quicker on my note 3 when using the otg cable. Can anyone shine any light on this? Thanks guys
No, E1 can not be used as Android's USB DAC. You will need at least E3 to have that.
Huh?? But it worked?? How bizarre. You don't think iv damaged it do u clie?
It is not designed nor advertised as an USB DAC for Android. If you get it to work, it is probably because of Samsung's own USB driver, not because of Android's default driver. But as Sam L has mentioned, the E1's internal DAC is pretty much low end and not worth the trouble for USB DAC on Android. I'll recommend E3 for the minimum, as the DAC inside is at least pretty good and at least a class better than the one in E1. E1 is more for small Windows tablet and notebook that have bad onboard soundcard.
I just returned the e1 cause I couldn't get it to work via usb otg on my note 3. There was no difference running the e1 through the 3.5mm jack vs. the dac onboard the note 3. In fact, since I'm running viper4android on my note 3 it sounded better without the e1 connected.
I'm going to hold out for the e5.
