Soundizer
- Dec 29, 2015
Yes got it now. I like that feature. I'm using it with mojo now to watch a movie. Really improves the experience. Much better than mojo alone due to the eq. Bass is pounding.
It takes a little time to get used to the settings on the E5. For me it was fairly easy because I didn't have to unlearn all the common tricks to get an amp like the mojo to work. You have to work to take away some sub bass, and just dial it to the sound you prefer.
Once you have the E5 figured out, you can start going back to adjusting your favorite eq on the source as well.
And yes, oh my yes, the E5 has amazing bass with IEM's.
I need your help because I am about to pull the trigger on a Mojo and want to figure out how you are getting comparable performance. I demoed a Mojo for two weeks plugged into my iPhone 6 and listening on my Sennheiser IE800 and found it to be significantly better than my E5. The soundstage was much more three-dimensional and lively. The separation was noticably improved and the treble spike that grates my ears was smoothed out. It was just better at doing what the E5 does in pretty much every respect. As someone who listens to hip hop and house, I thought the bass was much cleaner while still having chest thumping impact.
So what do I need to do to get my E5 to perform at the same level as the Mojo, as it appears many of you have pulled off? I am running it usually via bluetooth to my iphone or with a lightning cable. I have a pico slim amp connected to the line out in the E5 with an iBasso cable, which I've found gives the bass much more weight and clarity and makes vocals more present. I'm looking for the vocals to become crystal clear and enhance instrument separation, which I found significantly better with the Mojo. While the Pico Slim makes the E5 better, the IE 800s still sound muddy and collapsed.
Thanks for any help you can give!
Try this magic trick.
First TURN SBX off and then EQ 1k and above only to your preferred state of sound. Try not to over EQ, make it subtle - let me explain: if you prefer a 3db increase in 16k, only increase by 2db. Do not EQ anything under 1EQ, leaving Base Flat.
Then apply this magic - go to SBX and set the Crystal to 15percent only and try Base setting between 10 and 25 percent only. Leave Surround off.
On the Mixer set Bluetooth to about 70percent, careful when you do this as it might boost your device volume to max, so make sure your headphones are not on your ears. Turn the volume to low/mute on all other Mixer settings assuming you are not using them. I think you use Line In so ofcourse leave that on.
When listening always ensure the Soundblaster App is closed.
