I'm considering getting this for my PC.. I'm currently using a Hegel HD12 DAC which works great but the USB-port is defective so I currently use it through SPDIF/Optical out from my Asus Maximus X Apex motherboard. Which is also working out great. I use Voicemeeter Banana in Windows 10 and the Realtek ASIO driver.
My problem is when I sit at my computer and connect my Nintendo Switch. I have two monitors on my computer, and I tend to game on one and have a stream or something else running on the second one. I also do this when playing on console. The problem with the Nintendo Switch is the lack of optical output. I dock it in the docking station with a HDMI-cable to my primary monitor and then I have to take line-out from my monitor to line-in on the motherboard in order to get audio through my Hegel HD12 at the same time as I get audio from my PC. Connecting it directly to the Hegel won't work as I can't mix multiple inputs so then I would be forced to have audio from the PC or audio from the Switch.
I can also use line-out directly from the Switch itself while docked instead of using line-out from the monitor but as the monitor is stationary while the Switch is not it only makes sense to do it the other way.
My problem is the noise... The audio is simply horrible no matter what I do. I try to have low amplification on the line-in port on the motherboard and instead go with high volume on the monitor or the switch and the other way around but the noise floor is awful. Constant high pitched noise in the background and the audio is sparkling and crackling all over. I did not have this much of a problem with the audio before I did my upgrade, back then I had a Asus Rampage IV Extreme with defective on-board audio so I used a dedicated Creative Titanium HD audio card otherwise it was the exact same setup with HDMI to the monitor and line-out from the monitor to line-in on the Creative card. So I suppose its do to horrible amplification and horrendous shielding on the motherboard audio?
When playing other consoles like the Nintendo Wii:U, PlayStation 3, PlayStation 4 etc this is not a problem as they all features optical out then there is no noise whatsoever. With analogue on the other hand... Due to the lack of PCI-Express lanes on the Maximus X Apex as I already have 2x M.2 NVME drivers connected etc.. I guess I have to go external and I was looking at the Creative G5. Do you think it will do the trick?
