I can't guarantee that you'll like it better, but...
the DAC inside G5 is a bit below the one in Burson Play
Cirrus Logic CS4398 inside G5
Also, the AMP chip inside the Klipsch is exactly the same as the one in G5, so it may not feel like a big upgrade - Texas Instruments TPA6120A2 . In fact, the Cirus Logic DAC in G5, depending on how well the klipsch one is implemented, may be above the klipsch one
Burson Play uses ESS9018 which is above the Cirus Logic in G5, at least in virtually every implementation I have seen, in terms of details, clarity and overall soundstage / separation / resolution.
The version inside klipsch is a mini version of the same ESS DAC.
Now, about the OP-AMPS, theoretically, the ones in G5 and Klipsch are better than the ones in Burson, but, you can upgrade the ones in burson, and the full class A power deliver included with Burson Play may actually make up for it.
I heard Burson Play and many DAC/AMPs in the entry-level area, Burson Play, if you have HD800, should do you wonders.
If I may I ask... In that same kind of detail, how does the combination of khadas tone board and JDS Atom amp compare technically to g5 and burson play? Do you know what the chips used in them are and are they better?
edit: apparently the chip in khadas is ESS ES9038Q2M so better than the CS4398 in g5, I reckon.
