wwwpuntoit
- Oct 12, 2015
ok will try it out, thanks
Seems like everything is Ok. In regards to bad audio while in surround, you could maybe try messing around with the EQ, or just always using stereo. I'm not sure about the 5.1 thing but I don't think that there should be a difference, but I never had issues with 7.1 mode either.Hi, i'm new in this forum but I've been reading it without being registered for a while now. Thanks to the reviews I've read here I decided to buy a Beyerdynamic DT 770 PRO (80 ohm) and the sound blaster we are talking about here, but now I have a handful of question regarding surround virtualization because I'm new in all of this:
1-First of all: I've installed the Acoustic Engine Pro, set my headphones to 7.1 virtual surround, and configured the SBX profile to use a surround of 67 and nothing more. Then, on the sound tab of the control panel on windows I've set the quality to "24 bit, 96khz (studio quality)" because it previously was on DVD quality. Is there anything more I should configure or is it all ok regarding this initial step?
2-Music sounds weird through this 7.1 setup or, at least, different to how I'm used it to sound. This happens whether I use SBX surround or not, but it sounds normal if I set the headphones to stereo. Do I have to switch between 7.1 and stereo everytime I want to listen to music? Luckily I'm not such a music guy, but I've found that when I'm using the speakers set to 7.1 some programs sound distorted (like that "ear rape" effect in some videos) without a bit of tweaking (e.g lowering the program's own audio slider). That doesn't happen in stereo, so it would be useful if I could switch back and forth between stereo and 7.1 automatically. (EDIT: I've discovered that by using a diferent API in AIMP (WASAPI Event in particular) I can get rid of all this problems: stereo audio and no distortion. )
3-Why is virtual 7.1 surround way louder than stereo?
4-Is there any point in setting the headphones to 5.1 virtual surround? Is there any benefit in it, maybe more compatibility? What happens when the source is 5.1 but the output is 7.1 surround?
5-For movies I use MPC-HC. Do I have to configure anything to enjoy virtual surround there?
That would be all for now, thanks a lot.
You don't need it on PC.Hi!
How can i enable the Dobly decoding on Blasterx G6 in windows 10???
Im using G6 wth PC via USB, but i cant enable dolby....I tried force VLC to use dolby...Tried DTS movies, DD5.1 movies, dolby movies..Nothing. Thanks!
About to buy Sennheiser hd800s and I have the sound blaster x g5. It has served me well for 3 or so years. Originally I bought it just to get rid of the humm from internal sound card that seemed to get interference from my graphics card and it worked for that very well.
Is this sound blaster actually capable of driving high end headphones or do I need something better? Would Klipsch Heritage dac/amp be an audible upgrade from the g5?
Burson Playmate doesn't seem to have that balanced xlr port. That said, I have no idea how much that matters. Playmate is more expensive though so I'd need to know what the advantages are.
I don't mind paying a little more if there is some advantage there. But the way I see it now is that Klipsch Heritage thing has the balanced port and is cheaper, so the balanced XLR cable of the hd800s would just go there without any adapters. I've heard people say the sound stage is better with balanced cable.
Oh, and that Klipsch amp looks real nice too and has nice switchety switches and knobbety knobs. It really looks like it should have a tube on top though.
Meanwhile the Burson thing does not have that balanced port, yet it is more expensive. And it looks dull too though that does not matter at all if it actually produces sound that is clearly better than the Klipsch.
So if I was to buy the Burson one, there would have to be some pro, not just cons
This guy seems to like the Klipsch one:
Also, if I get the cheaper Burson amp, I start to enter the area where I'm not getting much or any audible advantage vs the sound blaster that I already have. So I might as well get no amp and just run with the gaming amp/dac.
Burson Play is 200 USD new from Burson.
But is it an upgrade from the Sound Blaster x g5?
Getting nothing is 0 USD from nowhere if I just stick with the sound blaster.
I want to know how much the Burson play is better and why, or is it.
edit: Like if it is clearly better than the sound blaster, at 200 dollars. Sold! If they deliver to Finland at least.
