Creative G5 discussion and reviews
Discussion in 'Portable Source Gear' started by evshrug, Dec 11, 2015.
31 32 33 34 35 36 37 38 39 40
42
  1. Evshrug
    Yes, it’s possible.
    You will want to experiment with distance between the mic and speaker, and also the microphone’s gain setting (in the Sound Blaster software suite) so that the volume doesn’t clip against the maximum input level.
    Also, keep in mind that the G5, the microphone, the speaker, and the whole audio chain connected to the speaker, will all impart their own flavor and distortion compared to the “master” audio source for your speaker.
  2. Dobrescu George
  3. Nuke142
    What is a next step after G5 for games and music up to $100? (for pc)
    Also i don't need EQ or any enchantments from audio card..
  4. Yethal
    Not a lot of gear for $100. You may want to try Fulla 2.
    Nuke142 likes this.
  5. Nuke142
    How about <200$ ? Will be any positive results compared to G5 ?
    I use HD598SR and monitors JBL LSR305. All connected to G5 (monitors connected to line-in 3.5jack, phones to headphone input). So i need two inputs same time.
  6. Yethal
    Idsd bl nano is probably the best $200 dac amp you can have.
    Dobrescu George likes this.
  7. Dobrescu George
    At that price, it surely is one of the best there are.
    The only other option would probably be HIDIZS DH1000, which is also good, and different, but at 200$ nothing else that is worth mentioning that I know of yet.
  8. dwinnert
    I picked up one of these today on sale. Pretty impressed with the sound quality which blows away the on-board Realtek audio and compares really well to my Schiit stack and might actually sound a little better.
    BTW, what is the consensus on the issues mentioned here regarding surround sound quality in games? Been awhile since the complaints and curious if things are better with the latest drivers?
  9. StormFalcon
    Just got one of these for really cheap, it has been serving me really well except for one slight problem. I have no idea what any of the settings do. I tried scout mode and it seems to just make quiet noises louder, so that's a no thank you, EQ and voice changer are easy to understand, but what I don't get is all the SBX settings, and also the "advanced settings". The SBX has surround, crystalizer, bass, smart volume, and dialog plus. I have no idea what crystalizer does, bass probably just applies a bass boost through EQ, smart volume seems to do a similar thing to scout mode, and dialog plus probably boosts the mids. The question is, what does the surround setting do and how is it possible for there to be varying degrees of surround? I have a theory that it actually controls something more similar to reverb, but I'm not really sure. Also, in the advanced settings, you have the option to change from stereo to virtual 7.1. What is the difference between doing that and turning up surround in SBX?
  10. dwinnert
    Well, I finally gave up and returned mine. I could not get it to stay recognized by Win 10 no matter what I tried. Worked with CL and no go. Oh well, it did sound good.
  11. Dingle Berry
    I've read through most of this thread and I'm a bit confused about this product.DTS/dolby does not work on ps4/xbone, so that would mean no virtual surround sound on those platforms? Would this still function well as a decent DAC/AMP on those consoles?
    I primarily plan to use this on PC, is there any issues with virtual surround sound on PC, does DTS/dolby/etc. work fine on PC?
  12. DrKrFfXx
    Any word on the succesor of this one, the G6?
  13. Fegefeuer
    DrKrFfXx likes this.
  14. wwwpuntoit
    hello people,
    i can buy g5 30€ used locally, would it be a good device for music listening through my PC ?on my hackintosh volume is too low.
    thanks
  15. StormFalcon
    Yeah if you can get it for that cheap and it works on your computer than definitely go for it
42
