Beefy
- Mar 4, 2008
10µF is far too small for the output caps. Your corner frequency with even 600ohm phones will be into the audible range (26.5Hz), meaning you will get pretty bad deep-bass roll off.
Switching in, say, 300ohm phones in the future will be even worse, pushing the corner frequency to 53Hz.
I have an oppurtunity to replace the output caps with 630v/10uF paper-in-oil Ampohms. They're 65mm in diameter and 95mm in length.
