LCMusicLover
Alright everyone, I have the next big modification to my franken-crack ready. Meet the tube-rectified bottlehead crack! I completely re-implemented the power supply with an oversized power transformer capable of supporting a tube rectifier. The high-voltage winding is maida-regulated for a consistent, stable, low-ripple B+ voltage no matter what rectifier is plugged in. Any 5V rectifier is supported. I've tried 5U4G, 5U4GB, 5AR4, and 596 rectifiers with great success.
One neat thing here is that if I wanted to go back to SS rectification, I can! I have a SS plug-in rectifier that fits in the octal socket. This was tons of fun, and I learned a lot about power supply design in the process!
Under the hood you can see the maida regulator for the HV winding, as well as the massive heatsink attached to it. I managed to fit this while keeping all the previous upgrades in place, including the onboard DAC.
I also replaced the input wiring with shielded cable, as there were now AC lines closer to the input wiring. With the shielded wire in place, the amp is completely silent with no hum whatsoever from the new PT. It's silent using both the RCA inputs as well as using the onboard DAC.
Overall I am very pleased with how this turned out. The differences in sound are noticeable, and my BHC has never sounded this good! Aesthetically, it came out better than I expected too. I managed to fit the new transformer in such a way that it covered the massive hole in the top plate from the original transformer.
The regulated PSU definitely made the biggest change out of all the upgrades (aside from the speedball). Early impressions are that the sound is just flat-out cleaner and more resolving, and the bass is more defined and punchier.
Thanks! I like having ultimate flexibility of either tube or SS rectification.
I bought this amp — using w/ ZMF Auteur & Atrium, as well as 6XX. Definitely good synergy w/ ZMF — haven’t tried 6XX yet as I just picked the amp up yesterday.The impedance of the Rad0 is only 29 ohms, so this amp is a bad pairing. This amp is more suited for high impedance headphones like Sennheiser and ZMF (200-300 ohm or above headphones).
Funny part is how I fell into this amp — was hoping to do a try-out and someone posted a link to the listing — didn’t realize the seller was (relatively) local until we chatted.
So now I need power tube recommendations (already have lots of input tube choices) to synergize best w/ my ZMFs. My initial read suggests that Tung Sol 5998s are the ‘cream of the crop’. Concur/disagree? Any other recs — I’m looking for ‘max disciplined tubiness’ if that makes sense.
And I wouldn’t mind spending less than the ~$250 a TS 5998 will end up costing.
