Crack;Bottlehead OTL
Nov 18, 2016 at 8:15 PM Post #7,936 of 12,346
OK  guys just one more question before I pull the trigger.
the same ebay seller offered me a Western Electric 421A from 1978 for 250$
tests results are:
T1 10,750 T2 10,500 107% / 105% No shorts or gas leaks, low Micros. 1978 vintage double O getters.
is it good results?
Nov 18, 2016 at 8:48 PM Post #7,937 of 12,346
tests results are:
[COLOR=231F20]T1 10,750 T2 10,500 107% / 105% No shorts or gas leaks, low Micros. 1978 vintage double O getters.[/COLOR]
[COLOR=231F20]is it good results? [/COLOR]
This place has 5998 Chathams for $100 and $150
http://www.vacuumtubes.net/RES%20Audio%20pages/6080.html
Nov 18, 2016 at 9:43 PM Post #7,939 of 12,346
Nov 18, 2016 at 9:57 PM Post #7,941 of 12,346
Nov 19, 2016 at 4:38 AM Post #7,942 of 12,346
   I thought to remember you once left SEX as is, because your maximally modded Crack was sounding as good or better?
And @NightPhotograph if you think that Crack is big. Jamie once used one with 100uf PIO cans attached to it externally.
The Sex has better resolution and soundstaging than the Crack period no matter what the mods. But the Sex's presentation is a bit cooler than the Cracks.
Loquah's detailed reviews of the Crack, Sex and Mainline are spot on imho check out the link
http://www.head-fi.org/t/683012/bottlehead-amplifier-discussion-comparison-thread-crack-sex-mainline
Nov 19, 2016 at 5:05 PM Post #7,943 of 12,346
What's the 'official' way of securing the top plate/guts to the wooden base? Don't want the damn thing lifting up every time I am pulling a cable out.... Or smashing more tubes.
Other than this horrendous flaw... Speedball crack is indeed a magnificent pairing with HD650s.
Compared to the stock Valhalla 2, the treble is mores extended as is the bass. The stock Valahalla2 isn't as extended on both ends. Lacks sub bass and unable to decode and correctly render/resolve/separate frequencies around middle c. The crack sounds more correct to me.
Nov 19, 2016 at 10:35 PM Post #7,944 of 12,346
Quite simple. Hold the plate down with one hand, carefully remove what you need to remove with the other hand.
Nov 19, 2016 at 10:55 PM Post #7,945 of 12,346
You could screw down the top plate I guess but I don't think that is necessary if you pull the cables out as normal human beings. I don't have a problem one hand to secure the unit and the other to pull the cables. If you think you should be able to yank on the input cables to change them out then you are the problem not the amp. Sorry but I have no sympathy.
Nov 20, 2016 at 12:26 AM Post #7,946 of 12,346
No its not like that at all. I merely assumed that a consumer product housing lethal voltages would...
Look, nevermind it is an awesome sounding amp. I am stoked.
Nov 20, 2016 at 5:19 AM Post #7,947 of 12,346
If you use your Crack in a environment where there are children with small inquisitive fingers then personally I think it is essential to take some precautions keeping the amp and power leads well out of reach for starters but also it's easy to add some small right angle brackets on the inside of the wood enclosure which will allow the top plate to. be fastened down and some wire mesh to be added cover the underside just in case.
Nov 20, 2016 at 5:56 PM Post #7,948 of 12,346
Hi all
I have a chance to get the 421A from an eBay seller (not to many reviews about him)
for 280$ including shipping.
http://www.ebay.com/itm/Western-Electric-421A-Electron-Tube-Code-8113-Tested-/252612290412?
he have some sort of image with a test result.
does it look genuine?
THANK YOU!
Nov 20, 2016 at 6:25 PM Post #7,949 of 12,346
$280.....way to rich for my pocket!!
I have bought many tubes from Ebay sellers and have had to send some back just because the were really sensitive to movement , vibrations, microphonic, humming, shorted heater....
If I were to spend $280 on a single tube I would want a solid assurance you can return and get a refund if there are any issues on your end.
A fool and his money are soon parted, just be careful....
Good Luck!
Alex
Nov 20, 2016 at 6:35 PM Post #7,950 of 12,346
Good Luck!
Alex
I will ask for 14 days return grantee, if he answer yes is it a solid assurance?
also, he said the tube is from 1981. is it possible?
In his pics I can barley see the hard yellow print that is related to the 421A. it look more grey to me. and the font is very different than all that i've seen!
