Ipod touch 6g 128gb, relisten or kaisertone apps, COZOY Aegis.
No cck annnnd 24/192!
0.4ohms or 4ohms?Might need to have the ears checked . My measurement shows the output impedance is around 0.4ohm or so.
Here: search 'head pie'Would like to join but I can't seem to find your Facebook page.
Ooh nice. So it plays well with multi driver IEMs and most other portable gear. Cool.0.4ohm, triple checked.
I tested and picked up one of these guys while I was in HK this past week. I had a couple questions - has anyone gotten the firmware update/software to work? I downloaded and installed (via setup.exe and setup1.exe) on my Windows 10 system. I get two apps, CozoyAegis (BRAVO-HD Audio Control Panel), which shows up blank, and COZOY-UAC Audio CPL (COZOY-UAC Audio Control Panel) which has stuff for me to select (bit-rate, frequency-rate, and buffer size) but shows the ASIO Device as "Not Available" and State as "UNLOAD." I'm less interested in high bit-rate for desktop usage (I have a good desktop dac/amp already), just being able to see and upgrade the firmware. Am I misunderstanding what they mean by firmware (ie, do they just mean Windows drivers, and not device firmware)?
The second thing I noticed (it was not a problem with the RHA T10i's I've been traveling/tested with when I bought the Aegis), is that my Aegis seems to not play nice with some IEMs - Noble K10s, Campfire Jupiter seem to have a soft high pitched (like a soft 10KHz) tone when plugged into the Aegis. Others, like the Savant, Oriolus, FitEar 334s seemed fine. Is this normal? I dropped Cozoy a line, and they didn't seem to really clear it up (they told me to "trust my ears," not sure they'd like the answer there), so just wondering if anyone else has encountered this? Maybe I just have a bum unit? Has anyone else auditioned a bunch of IEMs with this?
Honestly, after all the recent conversation I pulled out my Aegis this evening attached to a Note 3. With ClieOS' output impedance measurement in mind I confidently plugged in my 11ohm Fidue A83. Apart from some minor background noise this little Aegis can put on a fine show, right up there In sound quality terms.
So, @H20Fidelity, as a current Windows Phone user, the Aegis has been strictly on laptop duty for me (and I love it!), but I will be returning to Android in the next 4-5 months. How would you compare the sound from the Android + Aegis combo to the sound from the Pono?
