dfkt
- Jul 20, 2005
You can also use Rockbox, it's free. You can put an .apk any way you want on an Android device, as soon as it's on you just have to click it to install.
Have people got Spotify working on their Z2?![]()
Yes, I have both Spotify and Mog working on my Z2.
Spotify's Android application has some major issues at the moment though. On non-phone Android devices, you cannot sync offline music, otherwise it will become stuck in an infinite "you are offline/you are online" loop. If you do not try to sync offline, then it will stream just fine.
Thanks for that.
Have you tried playing around with the settings?
wow. I can't believe I got completely ignored. I might as well forget those 2 questions and try a question related to the above post, and maybe have a better chance of getting acknowledged.
From what I've heard J3 is the best sound quality and everyone has been asking whether the Z2 sounds better than the J3. Izzy I understand you don't have a J3, anyone else can you answer this? From what I know the J3 has Jet Effect 3 while the Z2 has an improved Jet Effect 5.
"Yes, you can make a playlist"
Would you be so kind as to give me a hint. I tried copying the M3U files from my S9 without success.
Is there something special I need to do?
Thanks in advance.
Diego
