PaganDL
- Feb 1, 2016
Yes it does...thank-you for responding That's kind of what I figured-- a big lure to this player was its capacity for EQ/sound manipulation, and I figure that if I'm not happy with any element I can just adjust it until I am. I have heard lots of great things about the "Cowan sound" get the sense they're something of the hidden gems of the DAP world for those who prize sound quality above all. Stoked to hook up the PR to my Solaris!
Hi @Rockwell75,
Honestly, as stated, it all depends on you, for Cowon Sound, subjectively & personally, I much prefer Plenue D or Plenue D 2 to R's sound, particularly since both Ds have a louder sound level at lower volumes & on the go have less issues in a tight pocket on the go.
I don't know whether Cowon Sound would be considered a hidden gem or not as it all depends on whether you do research & what your preferences are, more importantly, trust your own ears & not follow the hype train.
As a general rule, there is often too much hype & unhelpful information on headfi, especially with a lot of sheep leading the charge, this is certainly not a dig by any means, it just is.
Also, from experience, the Solaris doesn't play well with complex music which is not really surprising given it only has one crossover point which seems to be placed in the lows only though your mileage will certainly vary.
I be curious to see how things turn out for you.
Hope you have a great day !
