AudioMan2013
- Mar 4, 2013
AudioMan2013: thanks, yes, I'm aware of the limitations of computer USB ports for charging, which is why I've been using a wall outlet power supply at home (with surge protector). A surge protector at the office for a ac wall outlet will require an extension cord to reach the area in which I sit. I am going to consider that, for the benefit of prolonging the battery life. I'll look for a small surge protector I can take to the office on my commute.
I don't have to worry about the authorities above me thinking I'm downloading data from my computer, fortunately, because I can easily keep whatever I plug in from connecting in a way that might result in that - we have such software built in to our computers, as humble as they are.
Yep, I'm lovin' the P1 - I'm hearing details and separation I didn't think was possible from portable equipment. I'm buying more music now.
Cheers,
Jeff
Either that or you can get something like this: https://www.amazon.com/Vinsic-20000mAh-External-Portable-Smartphones/dp/B01M0J5N37/ref=sr_1_7?ie=UTF8&qid=1487716592&sr=8-7&keywords=portable+external+battery+charger+usb
If the power outlet is far from where you sit, I would just recommend to use the USB port on the computer or an external battery pack. The advantages outweigh the disadvantages of computer USB ports.
