Cowon PLENUE M2 (Current Firmware and Manual Links in 1st post)
Oct 28, 2019 at 8:40 AM Post #436 of 545
On my PM2 with the battery mod Im on 17 hrs of use with Flac and 320 MP3 files and battery is way over 60 %.
Nov 2, 2019 at 10:40 PM Post #437 of 545
Inside the PM2:
I bought a PM2 here on headfi to see if I could replace the PCM1795 with a PCM1792A and possibly upgrade the opamps/caps. First look is promising regarding the DAC (see below) not much info available other than its pin and mode compatible.
Cowon use a modular DAC/AMP design (just not for the end users)
Very interesting is that they are using the Plenue 1 DAC/AMP board but with different Audio Hub, DAC and OPAMP. Also notice the system board is the same as the older Plenue M, so basically they made a new product out of 2 very good older ones and put it in a new case with a new name but for a lower price (lower R&D cost) win win for us.
P1
Audio Hub: WM8998 (incorrect? @Windows X)
DAC: PCM1792A
I/V LPF: OPA1612 x 2
Output/Buffer: OPA1612
P1 pic from fidilizer
PM2
Audio Hub: WM8804
DAC: PCM1795
I/V LPF: OPA1612 x2
Output/Buffer: AD8397
Another newbie question - those components with “S7 Ap” written on top are the capacitors aren’t they? I can’t seem to find what make/model they are.
Nov 10, 2019 at 3:08 AM Post #440 of 545
Im using it almost everyday and Im just charging it once every 3 weeks.
Nov 11, 2019 at 1:50 PM Post #448 of 545
Nov 27, 2019 at 6:16 AM Post #450 of 545
Ok , now Im getting 25 + hours of battery use , but can I put a 400 gig card in this dap ?
