Even though I'm getting a decent tax return. It won't be enough to buy the Cowon P2.
Wait for next years tax return and by then it will be cheaper and you will have extra $$.
I wonder if P2 has a screen protector pre-applied on it or it must be bought separately.
You can convert vrms to W with an online converter for a given ohmageI knew that someone will replay that way.
I was talking about mW per channel @ 32 ohm.
Try to answer that now
P = V^2 / R
P = 2^2 / 32 = 4 / 32 = 1/8 = .125 = 125mW
That's an idealistic scenario for an infinite power source.
The main issue with these DAPs is that it runs out of current at low impedance loads.
So a specifications voltage or power at a particular impedance does not correlate nicely at lower impedance loads.
OK take my X3 and give me that discount.It seems like Cowon is organizing an exchange program for players from other brands?! For instance you send your DX200 and get a 540$ discount on a Plenue 2. This seems incredible, unless my understanding is wrong.
[COLOR=1D2129]I suppose only in Korea...[/COLOR]
http://www.cowon.com/event/?EVENT_NUM=435
Here is the Q&A in google translate
Not yet, but close.Is it available for purchase in US yet? I cannot find any one carrying it.
