Feb 19, 2013 at 5:10 AM Post #211 of 221
I find that it's largely dependent on the recording and genre; I almost always use 'Normal,' Headphone 1,' or 'Wide.' Normal and Wide are fairly flat settings while Headphone 1 has some bass and treble boost. I used to play around with the eq, but I am pretty happy with the three I mentioned. My music is all of very high quality (I search out the best mastered albums by musicians I like, as well as vinyl rips), so there's not a lot of tweaking needed to be honest. My iems are VSonic GR07 MK1 which are fairly neutral, fwiw.
Mar 30, 2013 at 10:17 PM Post #212 of 221
For us poorer folk who have good taste in headphones but cannot fork out $500 for a fancy pair of Shure IEMs, the Klipsch Image S4s are a great option. And since there doesn't seem to be any EQ settings on this thread for the S4s, I'll share mine.
EQ Option 1
80Hz - Wide - +5 dB
500Hz - Normal - +3 dB
1.4kHz - Normal - +1 dB
4.1kHz - Wide - +4 dB
13kHz - Narrow - +9 dB
BBE - 9
M3B - 7
3D - Off
MPE - On
SE - 1
Reverb - Off
EQ Option 2
80Hz - Wide - 6 dB
500Hz - Wide - 2 dB
1.4kHz - Narrow - 1 dB
4.1kHz - Wide - 5 dB
13kHz - Normal - 6 dB
BBE - 8
M3B - 6
3D - Off
MPE - On
SE - Off
Reverb - Off
These are both bass-heavy EQs. Feel free to tweak them if you'd like. They still handle the highs well, though. I'm listening to Maroon 5 right now, and the highs haven't sounded harsh at all.
Also, why is it that many on this thread like their dB levels down between 0 and 4, and their BBE & M3B either low or comlpetely off? With my S4s, those settings sound like trash...
Mar 31, 2013 at 12:22 PM Post #213 of 221
EQ Option 1
80Hz - Wide - +5 dB
BBE - 9
M3B - 7
3D - Off
MPE - On
SE - 1
Reverb - Off
EQ Option 2
80Hz - Wide - 6 dB
500Hz - Wide - 2 dB
BBE - 8
M3B - 6
3D - Off
MPE - On
SE - Off
Reverb - Off
I'm curious what you would think of the following settings for the S4's.  I was always curious about the opinion of how setting for the Brainwavz M2's would translate.  However, in the end, of course it's still opinion.  But hey, I think it's worth a shot.
http://www.head-fi.org/t/531603/cowon-j3-personal-user-eq-settings/60#post_7399629
Apr 5, 2013 at 1:00 AM Post #214 of 221
About a week ago, I tried both of these, not extensively, but I found the "casual listening" setting to be pretty good. I didn't like the other as much, though...
Apr 5, 2013 at 1:20 AM Post #215 of 221
Oh, well ok.  Interesting.  Well yeah, I could tell that your settings are even more v-shaped than what I have as the "casual listening" settings.  Alright then, good to know.
At least that means they're somewhat fitting.  I guess I won't know for sure how similar these two pairs of IEMs are until I hear them for myself of course...  Thanks for the feedback!
Apr 6, 2013 at 4:01 AM Post #216 of 221
Try this. Works great on My Cowon Z2 plus SE535:
Frequency / EQ:
80hz wide 7
220 hz normal -1 ( minus 1 )
1.4 kHz narrow 5
3 kHz normal 8
11.7 kHz wide 9
BBE+:
BBE= 10
Mach3bass= 6
3D sound= 3
MP Enhance= On
SE= 3
Reverb Off
Apr 8, 2013 at 4:00 AM Post #217 of 221
Hi try mine
i'm Using J3 with westone 4R + ibasso D-zero
EQ setting
Westone4R V2
Frequency / EQ:
80hz wide 8
220 hz wide 6
780 kHz wide 2
3.0 kHz wide 12
13 kHz wide 11
BBE= 10
Mach3bass= 10
3D sound= 1
MP enhance= On
Stereo endance= 6
Reverb Off
Tips: For ballad, guitar acoustic songs and as for kpop listen to how the acoustic guitar sound on (narsha - i'm in love).  lastly remember to lower your volume below 5 before using this EQ cause it's will boost the volume. sorry for my bad english
May 2, 2013 at 7:22 AM Post #218 of 221
Good afternoon everyone.
Any idea what would be the best settings for a fidelio M1 ? I listen to almost everything and for the moment I let everyhting to neutral, with a little bit of BBE.
Dec 27, 2013 at 2:25 PM Post #220 of 221
Hello !
Anybody knows how can I get the same effect as in Maestro preset using Personal EQ ? I really like Maestro and want only decrease midbas range a little...
Thanks in advance !
