AmberOzL
- Dec 18, 2012
What did you edit and why?
Tre treble part, end of the sound paragraph I believe.
Mainly my opinion on the treble and bass. In the first iteration, I stated that the bass was only boosted by about 3-4 db. That might be so, but only compared to the already warm-ish mackie monitors. So I removed that part. After spending some time with the AKG K702 annies, going back to the BA4f makes it clear that the treble is the weakest link in the BA4f. So I also added that bit.
In short, the review is a little harsher and more honest now!
Funny, when I read your review I feel like you are describing my monitors, but you have F version and I have R version:confused_face(1):
Not exactly. I will try to explain this more precise.
Let us assume that I have R version and you have F version and that F version have 3 db boost in the bass in comparison to R version.
Then, if you were saying that in your F version you have to lower the bass by 3db and I would do nothing with my R version then I would agree with your statement that we are hearing the same thing.
But, please note that I'm also lowering the bass by 3 db and we both do this in order to have more balanced/clearer sound. So, either I mistakenly have F version (but Phil told me that according their measurement I should have R version) or you ears tolerate more bass by around 3 db.
I'm a bit disappointed because now the sound is perfect butto solve the problem it needed to break the previous shell and built a new one. But the fit of the new shell is worst than the previous one that was perfect.
If Phil says you have the reference version, you have the reference version.
I think your ears got used to the bright sound of the etymotics. And I came to terms with the slightly softer treble (I also turn the treble up a bit in the EQ)
I'm getting a little bit worried if my ear molds got to Sweden safely. Should have had a message that they'd arrived by now...
Right, I don't know if Phil read my post, but about half an hour later I received confirmation that they've arrived
