StanD
- Oct 2, 2013
When it comes to headphone cables, unlike microphones, the impedance is low and there is no gain so RFI pickup, etc is not an issue.
for single ended RCA coax there is valid reason to use lots of copper in the shield - chassis leakage currents will create a V if they flow in the shield/ground return - the only way to reduce this is to make the resistance lower
All else being equal, the resistance will go down and the capacitance will go up. Into higher impedance loads, the cable's capacitance will contribute more to high frequency roll off (into lower impedances inductance will contribute more).
The only concept behind it that I can see is that 8 is a larger number than 4.
se
Hey Steve....
Do you mean that, for instance, 650s might appreciate less high freq roll off with thin or fewer stranded wire, while 880s and T-1s which are on the opposite side, might sound better/smoother with thick or multi-stranded wire?
I am a bit surprised with this... I wonder what kind of difference silver vs gold will have. Also, is there any material better than gold for a headphone cable?
Yes. Silver...and copper.Also, is there any material better than gold for a headphone cable?
Unobtainium is nice, but you have to get high grade strands to avoid flux convection.Yes. Silver...and copper.
And Unobtainium.
Professor Emmett Brown solved that some time ago.
Arrrrgghh!
se
