LoweArt
- Nov 4, 2006
I have no trouble driving either the Grado SR80 or SR325i on my MAD + Purist Custom or Darkvoice THA 336i and they are both tube amps.
I prefer the SR80 over the SR325i and subsequently sold the SR325i because I couldn't listen to them comfortably after 45mins due to the strident/shrill highs on them, even after over 500hours of use/break in. When I used the Grado SR325i on the Stello HP100 a solid state headphone amp, the highs were even more ear piercing and I wouldn't be able listen for more than 10 to 15mins.
At the end of the day, there are good & bad tube amps and the same goes for solid state. In addition to the good and the bad, there's also synergy between components ( ie. between source, amp and cans ), but when you strike the right mix, you'll never look back !
Originally Posted by bhd812 /img/forum/go_quote.gif Grados mesh with SS better then tubes any day anytime. 650's mesh better with tubes any day anytime. Grados are harder to drive on tubes then the 650's and to get any real good sound will take a better amp (higher priced) or better grados...well both actually. Using sr80's I would not waste the money into a low end tube amp being the headphones won't gain much, the tubes don't go with the headphones, the quality of the tube amp won't be worth the price at this level... I would invest in a better source or headphones then the amp..at least when thinking along the lines of sr80's. if your going the tube route Run the 650's with a good amp and a good source. |
