ProtegeManiac
I got my studio monitors yesterday and connected everything with some cheap RCA cables (just temporary, I couldn't wait on the cables, because there were only two speakers left). They are a set of Focal CMS-40 and they sound great so far, but I do have one problem with them. They make a constant hiss, which is coming out of the tweeters of both speakers. I disconnected the RCA cables on the speakers and the hiss remains. Changing the volume on the speakers also doesn't make any difference. Any idea what's causing this? Or should I create a new topic/thread for this?
How close are the monitors (the one for you ears) to the monitor (the one for your eyes)? Studio monitors unlike speakers that have a Center speaker in the same series (ie they expect the mains and Center to be near the HDTV) might not be shielded. Also try keeping wireless devices away from the room, including switching off your WiFI router, just to check if any of those are causing it.
You can also try a power strip with a noise filter and have only the two speakers plugged in there. Maybe plug it into a different outlet and have nothing else plugged into that (both the power strip and the outlet). Make sure all connections are properly grounded (ie don't use any 3-prong to 2-prong connections).
