Sep 1, 2007 at 11:47 AM Post #136 of 169
Perhaps you might want to update the list?
AOS Electronics and Xenos (alas!), are no longer in the headphone amp business.
Sep 3, 2007 at 6:09 PM Post #137 of 169
DIY design developed by AMB.
Inquire about having one prebuilt by MisterX or thrice.
-Amp name/model: Mini³ ("mini cubed")
-In production? Yes
-List price: DIY: varies, approximately $75 USD in parts; Prebuilt: contact builders for pricing info
-Current "street" price: n/a
-Type of amp: Solid state (opamp based) portable, 3-channel active ground. Two versions available: high performance (HP) or extended runtime (XR).
-Stock tubes: n/a
-Crossfeed: None
-Other processors: None
-Portable? Yes
-Power supply: 9V NiMH rechargeable battery, onboard charging circuit with external 15V-24V AC-DC wall adapter.
-Detachable power cord? n/a
-Number of headphone jacks: 1
-Jack output impedance (per jack, if more than one): < 0.01Ω
-Jack output (per jack, if more than one -- include @ #Ohms) n/a
-Jack type: 3.5mm mini phone jack
-Inputs: Line in
-Other outputs: n/a
-Output power, HP edition: 300mW/ch into 32Ω, 30mW/ch into 300Ω
-Output power, XR edition: 180mW/ch into 32Ω, 30mW/ch into 300Ω
-Possible upgrades/upgrade path: n/a
-Input Sensitivity: n/a
-Maximum Gain: 5 (14dB) default, can be built to other gain settings
-Input Impedance: 10KΩ nominal
-Output Impedance: < 0.01Ω 20Hz - 20KHz
-Total Harmonic Distortion, HP edition: 0.0011% (RMAA, 300Ω load)
-Total Harmonic Distortion, XR edition: 0.0023% (RMAA, 300Ω load)
-Intermodulation Distortion, HP edition: 0.0064% (RMAA, 300Ω load)
-Intermodulation Distortion, XR edition: 0.0070% (RMAA, 300Ω load)
-Frequency Response: 0Hz - >4MHz, +0, -3dB (limited by test equipment)
-Slew rate, HP edition: 52V/µS, 100KHz square wave
-Slew rate, XR edition: 162V/µS, 100KHz square wave
-Rise time, HP edition: 166nS 10%-90%, 100KHz square wave
-Rise time, XR edition: 54nS 10%-90%, 100KHz square wave
-Signal to Noise Ratio: 93dBA (RMAA)
-Stereo Crosstalk: -90dB (RMAA)
-Housing material: extruded aluminum
-Size (dimensions): 2.1"W x 3.3"D x 0.9"H approx, not including volume knob
-Weight: 5.6oz. including battery
Oct 28, 2007 at 9:06 PM Post #139 of 169
out of all the amps listed on the first page ( the updated one), what amp would be the best for under 300 $ ( but preferrably less ) to use with darths? Preferrably should have a dac but it's not essential.
thanks
Nov 4, 2007 at 12:57 AM Post #140 of 169
thanks
Personally, if Im looking for a DAC and a Amplifier I really like the Fubar3. Its a great little gadget, love the casing and quality and its also under 300$ so pretty affordable IMO.
Nov 28, 2007 at 10:06 PM Post #141 of 169
Hi all, I've been out of touch with reality for a few years, what happened to Meier audio's portable amps? he's only got one listed on his site now and it's the one for us head-fi'ers. I was hoping that he had upgraded the porta-corda line or at least had some mods for it.
Dec 14, 2007 at 7:09 PM Post #142 of 169
I was wondering, would the PA2V2 amp be a good match with my creative zen v plus and modified grado sr80's
Dec 15, 2007 at 1:31 AM Post #143 of 169
When I had a PA2V2 I paired it w/ an SR125 and ER6i. I felt they had good synergy and enjoyed the sound. As a first amp or an starter amp it is IMO a nice one.
Dec 20, 2007 at 3:27 AM Post #144 of 169
merci beaucoup
jon/jmageshazam/jmagesizzle
Mar 21, 2008 at 12:53 AM Post #146 of 169
Originally Posted by ghart999 /img/forum/go_quote.gif
I was thinking that it might be worthwhile to start a thread listing the existing portable amps along with their price and website link. No reviews here, just a list. I have spent so much time trying to determine what options I have and would have loved to have a single source to get a list of the options. I don't know if this has been done before, so maybe I am reinventing the wheel. I will start and maybe others can add to this. Maybe we could get a sticky if this gets filled up enough. I would define a portable as having battery power. This list also includes portable DACs, no longer sold amps, and DIY amps. Prices listed are in US$ dollars.
__________________________________________________ _________________
I also found a link to pictures of various portable amps.
Courtesy of Duncan from ipod & portable audio studio
Portable Amps
ipastudio - world's largest portable audio galleries - portable headphone amps & DACs - Powered by PhotoPost
Home Amps
ipastudio - world's largest portable audio galleries - headphone amps, DACs & power supplies - Powered by PhotoPost
AOS Electronics - Flute DAC/AMP - $400 AOS Electronics Co. Home Page
AOS Electronics - Piccolo DAC - $270 AOS Electronics Co. Home Page
AOS Electronics - Pace DAC/AMP - $730-$890 AOS Electronics Co. Home Page
Dr. Head - Dr. Head - 149 Swiss Francs Digital Audio & MIDI from Audiotrak - Dr Head / Headphone Amplifier
Electric Avenues - Pocket Amp 2 - $60 Welcome to Electric-Avenues.com - More About The Portable Headphones Amplifier
Eyevancsu Amplifiers - CMoy - $50 - $110 auto insurance home loan credit at eyevancsu.net
Headroom - Airhead - $150 Products - HeadRoom - Right Between Your Ears
Headroom - Bithead - $200 Products - HeadRoom - Right Between Your Ears
Headroom - Total Airhead - $200 Products - HeadRoom - Right Between Your Ears
Headroom - Total Bithead - $270 Products - HeadRoom - Right Between Your Ears
Headroom - Coda Amp LE - $299 Products - HeadRoom - Right Between Your Ears
Headroom - Overature DAC - $299 Products - HeadRoom - Right Between Your Ears
Headroom - Supreme - $449 Products - HeadRoom - Right Between Your Ears
Headroom - Cosmic - $729 Products - HeadRoom - Right Between Your Ears
Headroom - Cosmic Reference - $879 Products - HeadRoom - Right Between Your Ears
Headsave - Go-vibe - $65 http://www.headsave.com/vibe.html
Headsave - Mint-Vibe - $60 http://www.headsave.com/vibe.html
(Note: Headsave no longer exists, so you would have to buy used.)
HPA - HPA-01A - price unknown Site Builder
JMT Audio - Mint - $90+ jmtaudio.com
JMT Audio - Pimeta - $150+ jmtaudio.com
Larocco - Pocket Reference - $510 LaRocco Pocket Reference
Meier Audio - Porta Corda MkII - $225 http://home.t-online.de/home/meier-audio/
Portaphile - Portaphile Mini - $115-$200 orderingb
Portaphile - The Portaphile v 2.0 - $175 orderingb
Prelude Audio - Symphony II - $125 http://preludeaudio.com/products/aud...mphony-II.html
Ray Samuels Audio - Emmeline SR-71 - $395 News - Ray Samuels Audio
Ray Samuels Audio - Emmeline XP-7 - $495 +$200 for PS News - Ray Samuels Audio
Rockhopper Audio - Mint - $80 - $90 http://homepage.mac.com/skatsaounis/...Audio/mint.htm
Rockhopper Audio - PiMETA - $190+ http://homepage.mac.com/skatsaounis/...dio/pimeta.htm
Rockhopper Audio - PPA - $200+ http://homepage.mac.com/skatsaounis/...rAudio/ppa.htm
Shellbrook Labs - Super Mini Moy - $95 http://www.shellbrooklab.com/mini.htm
Shellbrook Labs - Super Maxi Moy - $125-$215 http://www.shellbrooklab.com/maxi.htm
Simpl Acoustics - A1 - $150 simpl.com :: Brilliant Sound Made Simpl.
(Note: This amp only works with the iPod)
Sound Professional - Lafferty Headbanger - $99 Microphones, USB Microphones, Preamplifiers, Digital Recorders, Cables and more at Rock Bottom Prices from The Sound Professionals - Great deals on Microphone, Preamplifier, Digital Recorder, Cable and more!
Twinstarr - Blue Cmoy - $90 headphone amplifier twin star suns at twinstarr.com
Twinstarr - Red - $70 headphone amplifier twin star suns at twinstarr.com
Twinstarr - Black Apheared - $110 headphone amplifier twin star suns at twinstarr.com
Xenos - 3HA - $130 http://www.aptecpro.com/Xenos-Prod/X...ntro-page.html
Xenos - 0HA - $55 http://www.aptecpro.com/Xenos-Prod/X...ntro-page.html
Xin - Supermicro - $150 Cool Stuff
Xin - Supermini - $120 Cool Stuff
Xin - SuperDual - $160 (No longer available new)
Xin - Supermacro - $250-$350 Cool Stuff
Z-Audio - Zmoy - $45-$110 Z-Audio - Products
(Note: No longer made.
Z-Audio - Pimeta - $160-$350 Z-Audio - Products
Z-Audio - Epsilon - $80 Z-Audio - Epsilon
Z-Audio - Mu - $110 Z-Audio - Mu
Z-Audio - Lambda - $170 Z-Audio - Lambda
Thanks for the list,it saves the fingers from doing the walking.LOL
May 4, 2008 at 10:29 AM Post #148 of 169
Hi All,
New to this post so please bear with me...
To be efficient here is my question (and maybe I am insane)..
I am looking for advice on purchasing a portable amp/DAC that is on the small side that can actually drive bookshelf sized speakers. It must have the following:
-one USB input
-one optical digital input
-one stereo RCA input
-be easily switchable between these input (a remote would be amazing!)
-the DAC needs to accept 96khz and possibly upsample 44.1 and 48 to 96khz
Is this possible? Is there a product that can do all this? I have looked and cannot find anything. Perhaps a 2 part solution would be best--an outboard DAC and receiver?
...I am going out of country for possibly 2 years and would like to pick something up that can handle SACD output from my PS3(optical), iTunes output from my mac mini(usb) and be able to run an unforeseen third device through the RCA's. Also it'd be nice if this magical piece of hardware could then be incorporated into my soon-to-be high-end setup once I return home.
Thanks for listening all. If anyone can point me in the right direction on this I'd be grateful.
Please feel free to drop me a line at brettra2@yahoo.com.
Many Thanks!
Brett
May 21, 2008 at 1:26 PM Post #149 of 169
