Nomad
- Jan 24, 2005
Thanks for your suggestions bg4533.
I don't have problems with the headband (actually I did bend it quite a lot and it helped a bit). I don't know why, but it seems like I'm alergic or something because my ears become red after just a while (around one or two hours, it is even worse while moving). I like the sound for some music though, so I end some days using some kind of skin product after my sessions. I think this is not normal, but I don't know what to do.
I'm going to order some Senn 414 pads in order to see if it is a problem with the Grados material (on me) for some reason.
I'm a bit afraid about to place the Grados drivers in other cans as this might affect the sound. Besides, I like this mid-size form factor, almost portable. I even like the retro look (metal or wood. Not that much on plastic). I'll try first for a change in the material of the pad. I suppose the Senns 414 pads are my only choise (materialwise) at the moment.
If I find some alternatives I will post them. Thanks for your suggestions.
Cheers.
Cheers.
