dano1122
- Dec 7, 2004
Originally Posted by holeinmywallet There is one problem I see with this mod.. Because of the added weight from the pads, this means more pressure from the headband squeezing down on the top of the head. My discomfort from the grados mainly come from the the hard head-splitting headband. |
Originally Posted by holeinmywallet Is there a way to impliment the grado drivers into a readily available entirely custom made frames, such as.. taken from your K3000? The fact that I don't like the whole stock skeleton design grado frame. I am sure you are able to come up with. If such thing becomes available, I would bid on it in a heart beat to use with my grado. |
Originally Posted by Emon I've heard the Grados are very comfortable after a few weaks of breaking in. |
Originally Posted by nierika If Larry can make circumaural Grados, why can't Grado Labs make them? |
Originally Posted by nierika LTUCCI1924: If you do end up with circumaural Grados and keep them for more than a month I will be completely shocked. If Larry can make circumaural Grados, why can't Grado Labs make them? |
Originally Posted by taymat Because they're lazy. ![]() |
Originally Posted by BRBJackson Larry you are amazing... can't wait to hear reports on this mod. Any idea when pricing will be available? ![]() "So what kind of 'phones are those?" "They're modded Grados" "No really, what are they??" "OK, they USED to be Grados, then I let headphile have 'em for a couple of days..." ![]() |
Originally Posted by Permonic Not at all. Circumaural earpads make Grado sounds differently, especially soundstage. You can feel fullness of the presented soundstage The sound is less airy, which is an obvious difference between circum and supra aural sound. There is not big impact on Grado typical forwardness. Hence the design of inner part of the circumaural pads is tricky. You need to experiment a lot to find a synergy between bass, midrange and highs. Circumaural pads with materials of less porosity/more reflection make bass of Grado more bloated and tame highs a lot. A combination of foam layers and material leads to the superior sound than bowls and flats could provide. |
Originally Posted by taymat Also circumaural grados are bulkier than standard ones and ipoders (who buy sr-60s and so on, 60% of grados sales I read somewhere) would not be interested in them IMO. |
Originally Posted by holeinmywallet There is one problem I see with this mod.. Because of the added weight from the pads, this means more pressure from the headband squeezing down on the top of the head. My discomfort from the grados mainly come from the the hard head-splitting headband. Is there a way to impliment the grado drivers into a readily available entirely custom made frames, such as.. taken from your K3000? The fact that I don't like the whole stock skeleton design grado frame. I am sure you are able to come up with. If such thing becomes available, I would bid on it in a heart beat to use with my grado. |
