Sorry, I am French and I don't understand what RF means. It is Interference??
I also hesitate between the chord Mojo and the ifi idsd black label.
The Mojo is a DAC/Amp and the amplifier section of the Mojo is specific to the unusually clean analog out of the FPGA DAC.
Analog in would mean you want to use Mojo as an amp only, but that defies the purpose and would likely not work very well.
A conventional DAC chip generates a lot of noise and the amp has to filter it. Mojo’s DAC is noise free and the amp doesn’t have or need those filters.
And the Mojo magic happens in the DAC section.
But sure, if you need an external amp then Mojo doesn’t do that and you need another unit.
Just to be clear, the OP was comparing the iFi xDSD to the Chord Mojo. The xDSD does not have analog input. The more expensive Micro iDSD on the other hand does have analog input.
Nice to hear someone with another point of view! I'd love to be able to try them too.But sonically I prefer the iDSD Black Label. More dynamics and oomph. More meat on the bones of notes while the Mojo has a leaner sound. This will be a matter of personal preference in terms of sound signature.
Did you try with a longer USB cable? I find that with a longer USB cable, even if the distance isn't that long from each other, the RFI disappear.
By the way, did any of you have the chord mojo case? I like to have cases in general but this one feels expensive for what it is.
And regarding the case, I designed one myself for 3D printing, but also considered making one from leather. The nice thing about the 3D printed one is it’s open design that shows the Mojo logo and keeps it cooler
If you just want to pair a DAC with your PC or phone, I think the audioquest dragonfly red will be sufficient and much more convenient.
I have a 256GB micro SD in the R3, much cheaper than a new iPhone with that amount of memory
Because the SP1000 only stream Tidal and I prefer Qobuz. Perhaps the new SP1000 software will included some android APK but for the moment I prefer to use the mojo+poly.Well, you know, most android phone have SD card slot. I am really happy with the HTC 10, they make good phones! Thanks for your offer but for now I am happy with what I have. Wanna spend money on other thing as well You should try the AKG, they sound great! They aren't probably so expensive in Austria. Great value!
@Currawong I have seen your review before buying (written and video), one of the best I found. Thank you! I liked how you presented the versatility of the ifi and yet, you still mentionned the Mojo sounded a little better, that made me hesitate big time. What I think I would really appreciate on the ifi is the connection, the USB of the Mojo seems very fragile.. What I'd love though is fast charging with usb-c, percentage for the battery (not this stupid colors) and be able to charge while listening without feeling like I am mistreating the machine.
@popof94 But why not use the sp 1000 then? Mojo+poly then you've got two things to charge. It seems to me that the price of the poly is also quite expensive for what it does, like the case.
