Music Alchemist
Pokémon trainer of headphones
- Dec 17, 2013
I was infact curious myself so I went through the cable drawer. And wa-la mini jack to rca is got plugged in. Mojo got set to line out mode.
Result. Mojo produces alot of noise when charging, playing and in line-out mode. So while it's charging, it is produces a completely unacceptable hum both on the line and physically from the unit.
Running directly into my mainline while running on battery the hum goes away. The Mojo has boosted mid-bass compared to the Gumby, and most of the other things I said before hold true as well.
The sound just isn't a natural, it's like there is are right angles everywhere instead syn waves. Almost crunchy. After an hour, I couldn't take it anymore.
I then plugged a USB regen into the line, that smoothed things out a bit and added more air. Which was nice.
Honestly I like the Mojo better by itself than as a line out and definitely won't be using it that way... I'm guessing the Mainline + HD800 make it's flaws very apparent. Which is fine with me... it's not a Hugo... and it's got Mojo!
Thanks for your input. I have a 5V 2A wall charger permanently connected to the Mojo and get no noise. (You may have gotten one of the unlucky noisier units. But you should charge it to full while it's off, then trickle-charge it during playback, which could solve the noise issue.) I'm also using TOSLINK, which electrically isolates the DAC. (Some say it sounds better than USB.) And I'm using it as a DAC + digital preamp for active speakers. (I'll have a passive floorstanding speaker system next week.) I used to own an HD 800. The differences between the Mojo and solid state DAC/amps that cost thousands were minimal for me with that headphone. It's easier for me to assess DAC differences with speakers. I'm really curious about the Yggdrasil, so I dunno if I'll try the in-between multibit DACs. It's interesting how many conflicting opinions there are on Schiit vs Chord. For the record, they all (or rather, the Modi Multibit, Mojo, and 2Qute in my case) sound fantastic with my speakers, with each having a different presentation that enhances the core signature of the speakers in assorted ways. The 2Qute sounds considerably more realistic than the Mojo (especially in terms of resolution and dynamics), but costs a lot more, which is the main reason I parted with it. If I could only make one complaint about the Mojo, it would be that it's a little too smooth. (The opposite of crunchy in my experience.) I'm on the lookout for a more aggressive-sounding DAC that isn't particularly expensive. (Won't get back into higher-end DACs until a little later.) The Modi Multibit is the closest I've gotten to that, but it comes off as crude to me, and it also has qualities that I'd describe as tubey and emotional. (Which is nice, but not exactly what I'm looking for.) Perhaps I won't be able to find a DAC under $500 that has the aggressive, yet refined type of sound the 2Qute has.
