tuna47
Thanks maybe you're smarter than I am and can come up with an answer
Still sounds great either way but better from mac
Mine does the same high pitch tone while charging.
My previous mojo unit was faulty (was turning itself off) and I got it replaced - but he didn't had this high pitch tone issue.
So I'm also thinking about getting it replaced.
Hey Guy, So I have a weird issue. My Mojo used to show up as either 384 kHz sample rate on my mac, but now is showing 48kHz. I have checked with my iPhone which should show 44kHz and it does, but when plugging it back into the iMac, it goes back to 48kHz instead of the normal 384. Now I have also tested my SMSL M8 to see if the sample rate dropped on it but it turns on at a 48 and then when plugged in as the target it jumps back up to 384. I am not sure but this start happening when I put the Mojo into Line level mode when testing out the DAC with some AMPs I have. I know that this is not saved once I turn the Mojo off but I thought it was worth mentioning to evaluate what i was doing when this started happening.
anyone else have this issue or know how to have the iMac recognized back up to the 384 Sample rate?
Have you tried a different USB cable? Also, make sure that it is switched to 24-bit first. If neither of those things help, try using it through a USB hub and see if that makes any difference.
I tried several different usb cables. Now the mojo does stay in the 384 range when on my other Mac. It just recently started doing this on this Mac.
I think I missed something. How do you switch the mojo to 24bit first?
In Audio Midi Set-up there should be two options for the Format setting for any device. Sometimes when set to 16-bit a device wont go higher than 44.1 or 48k I've found.
Yeah, it is playing now. Not sure why it didn't before.
Media Go will happily play a HQ sound file... but not via ASIO. It appears to only use a standard sound driver (maybe DirectSound, or similar).
I have just this second managed to get foobar2000 working with the Mojo, and the colour of the power light changes depending on the quality of the music I am playing (i.e. it doesn't seem to be resampling everything to a set frequency, and is retaining the frequency of the file).
I am going to stick with foobar2000 for the moment, and see how I get on... and also, how it interacts with Steam.
