Had the Mojo in line out mode a few days before a trip .
Turned it off of course . Got on a plane a few days later and turned the Mojo on
and it damn near blew my eardrums out . It was still in line out mode !
It is supposed to return to normal after you turn off and have never had this happen before .
Anyone else have this happen ?
The rule is: Mojo will turn back on to the last level you set
manually.
I'll do my best to explain with a little exercise as it's not such a straight forward UX. Should be easy to duplicate yourself. Best to do the steps after State 1 without headphones connected. Just look at the colors.
Actions are in full capitals.
START
TURN ON
(1)
State 1: set to a good listening level for your headphones, i.e. typically one of the lower settings.
TURN OFF
TURN ON
(2)
State 2: Mojo turns on with same level as state 1
TURN OFF
TURN ON in LINE LEVEL MODE (push volume up+down)
(3)
State 3: Mojo turns on in Line level mode (i.e. 3V output)
DON'T TOUCH VOLUME CONTROLS!!
TURN OFF
TURN ON
(4)
State 4: Mojo turns on with level set to the level you chose last manually, i.e. State 1/2
TURN OFF
(5)
State 5: Mojo turns on in Line level mode (i.e. 3V output)
CHANGE VOLUME LEVEL DOWN e.g. 5 steps
(6)
State 6: Mojo is now in the level you set it at (e.g. 5 steps down from 3V --> 2V output)
TURN OFF
TURN ON
(7)
State 7: Mojo turns on with level set to the level you chose last manually,
i.e. State 6!!
It's that last example that messes people up and how I've had a sonic boom in my ears as well... Moral of the story, if you start up in line-out mode, adjust the level slightly and than reboot it will come back to that level.
