TG04
Well, let's see --
1. Under Playback,
(a) click on the word Output and another panel will open up, at the top select the [DSD:ASIO:ASIO Chord 44.1 kHz 768 kHz] from a long list on the pull-down menu, then close this panel
(b) click on the word ASIO under Output and a different panel will pop up, this is where you select [ASIO Chord 1.05] from a much shorter pull-down menu
2. under Tools, click on SACD and yet another panels opens up. At the top, you need to choose [DSD] or [PCM] as your preferred output mode and it is just that, a matter of preference If you select PCM a few more options will need to be made but the Output Device (in the middle of the panel) would remain the same in either case -- as selected under 1(a).
Please experiment with DSD and PCM output, I'd be interested to hear which you think works and sounds best. Good luck!
1. Under Playback,
