Metalsludge
- Nov 29, 2012
If it does turn out to be a fault with your Mojo unit, please don't feel that you have to abandon the optical input. Chord will simply ask you to return it to them, via your dealer, and will sort it out for you, one way or another. They stand behind the product (I'm assuming yours hasn't been damaged by misuse).
Even if you can see light coming from the toslink cable plugged into your AK120ii, it is still possible that the cable might have some damage that may be scattering the light or not transmitting it correctly into Mojos optical receiver. Can you try another optical cable?
Thanks, I will try the other cable I have again later when I get a chance. I think I already tried it before though after updating firmware, but I will try one more time now that I know what to look for with the light.
