martyn73
- Dec 8, 2011
Has anyone compared 2Qute to Mojo? Is it overkill to have both?
On Head-fi, nothing is overkill, nothing.
What is your source? Mojo with X2 using WASAPI and a quality USB cable did blow me away.
And Nighthawk and TH-X00 are on the way, but I really wonder what else can come.
2X. Something about the Mojo...I could not go back to Bimby or Dac 19 (10th anniv). And I really liked the Dac 19 but there was something about the Mojo that suited me.
Thank you for this little piece of information. I will be sure to snap an epic picture of the Mojo chilling at Machu Picchu or in downtown Miraflores and maybe I'll get one at Sedona, AZ on my upcoming trip in a few weeks.
THIS. Okay I have another question, so if I buy an OTG cable such as the one of these listed here: http://www.amazon.com/Cable-SanDisk-Clip-Sport-Player/dp/B00WTVI4SS or this one http://www.amazon.com/LIFETIME-WARRANTY-Electronics-Micro-Cable/dp/B005GGBYJ4
Does that mean that if I want to connect my Chord MOJO to have DAC functionality with my Sansa Clip Sport I must use a Micro USB B cable - > USB A and then use the OTG cable to connect it to my Chord Mojo? If I just go line-out from the Sansa Clip to the Chord Mojo input then that would skip the DAC section?? I am placing an order soon and I don't want to make a careless mistake and buy the wrong cable.
I want something like this, but with my Sansa Clip Sport being used instead of an iPhone or Apple device:
In my opinion nothing beats Mojo under $1000-1200. Neither portable, nor desktop.
iFi Micro is portable theoretically. In practice it is just too big for portable. Approximately 3 times bigger than Mojo.
Have you had a chance to compare the two?
What source.. im using my note 4 via usb otg using uapp as my player. flac and hd files.
Which Ifi Micro are u talking about? There are many Ifi products out there that are look similar.
Okay, so if my Sansa Clip Sport only has USB functionality of data transfer/charging.. what is the cheapest DAP that I can buy that outputs digital?? I don't plan on using my smartphone to store music so that is already counted out.
That's true, sansa does not suppost usb audio out. Cheapest option? Anything that has digital coax out (Fiio line of daps are popular) or usb audio out (cheap android phone off ebay?)
Thanks Bavinck. Right as you replied I took a look at the Fiio X3 2nd gen. That should do it
