Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
684 685 686 687 688 689 690 691 692 693
695 696 697 698 699 700 701 702 703 704
  1. heliuscc
    It depends what you like but USB from Sony A15, coax from DX50, and optical from RWAK100 and AK120 all sound different. In some ways I feel DX50 to mojo sounds best, but the UI sucks. Sony also sounds good. RWAK100 favourite all round package with mojo right now. That's size, shape, weight, UI, and sound.
  2. betula
    DX80 via coaxial was transparent and clear to me, but treble was too harsh. Computer via usb is the best so far, smooth with great bass., however there is a big difference what app and software you are using. (YouTube HD is congested and lifeless compared to Foobar with Asio) I am about to try android as a source, but heard all good and bad about it.
  3. heliuscc
    DX50 very similar to your DX80 description but I like that clarity. Sony sounded good but somehow congested. AK both seem more effortless
  4. kenman345
    Anyone use the Mojo with earbuds? Any recommendations?
  5. Mojo ideas
    There is a small sealed relay inside Mojo. This is what you are hearing.
  6. jarnopp
    Any that you like would surely sound great from the Mojo. But to get a goo response to your question, I think you will need to provide a bit more info, like budget, musical tastes, sound signature that you like...
  7. headmanPL
    Using the same audio files, I can't tell the difference on what is acting as the source
  8. faran
    I actually love that click. It gives me the impression that a thing of quality has been switched on and makes me feel that something great is about to begin and the click off tells me that the "trip/session" has now ended and normal service has resumed.
    headmanPL likes this.
  9. Pokersound
    I use VE Zen 1.0 and for me is better than Yuin PK1
  10. gordec
    Thanks. I wouldn't think it would given its all digital signals.
    Sent from my SM-N920V using Tapatalk
  11. San Man
    What type/kind of problem did you have with the sysconcepts cable?   You're the first I've read so far.   TIA
  12. jamato8 Contributor
    The only problems I have read, and that would pertain to any optical cable, is pulling it out wrong or straining the it by some means and fracturing the optical cable. I had one I did that with and it was my fault, not Sys concept. I have used their cables for years and found them to be the most reasonable priced and of the highest quality.
  13. jamato8 Contributor
    All that I have tried sound extremely good. The JH13 Pro to much lower priced monitors like the HiFiman series of in the ear monitors.
  14. Skampmeister
    I can't believe how anal people get when the mojo makes a little noise while charging. Does it charge, yes, does it play music for 8-10 hours, yes.
    Makes noise while charging, who cares.
    My car makes a noise when I turn it on.
  15. Antihippy
    Some people like to charge it overnight on their bedside table when they go to sleep.
    Maybe consider that other people's circumstances and preferences are not your own?
    Carl6868 and Hawaiibadboy like this.
