- Oct 14, 2013
How about some of these ? They can be found from target, Walmart, Amazon. Excellent for stacking
What are you guys using to stack your Mojo and DAP? Just a band? Do you put anything between the two?
I understand, but it does matter what you device and way of transport you use to feed a mojo, because I see clear Quality difference in dx80 vs note 5 feeding Mojo
The inventor himself said it doesn't matter. The way mojo was designed is to ensure that it doesn't matter.
I received my replacement unit from Moon Audio today. Plugged it in to charge and I have the dreaded whining noise while charging. I'm using the same Anker Powerport 5, the old unit was dead silent while charging. This one whines with apple's charger and mac mini's usb port also. The old unit had the startup hiss issue via HO, btw.
I believe this unit is from the latest batch that Moon Audio received this Monday. I thought this PSU regulator issue was resolved in the earlier production cycles. s/n on the new unit is M0278xx, could someone from CHORD shed more light on this?
I just saw 2 other new members having the same issue few pages back.
I just hear a clear difference from note5 to. Mojo than vs the dx80 to mojo.
Thanks. I have some bands from ALO. I'll also put something non sticky between the devices to prevent scratching.
It shouldn't, but if it does , that is the software that is used to play back. I hear it from Zx2-Mojo and Note4-Mojo. Note 4-Mojo sounded better than Zx2 feeding Mojo, better transparency and soundstage.
