- Feb 11, 2008
(click to enlarge)
I have just measured a Mojo into a 16 ohm load using an APX555 test equipment. With 1% THD 1 kHz single channel, Mojo delivered 3.30 v RMS - that's 680 mW. Using 50 Hz, it was 668 mW RMS.
Rob
Rob
Uggh, stop making me want this Head-Fi. h34r:
(repeat mantra: "I am perfectly happy with the gears I have. I am perfectly happy with the gears I have. I am perf.....")
Hi Rob,
Could you do a similar test on a 300 ohm load?
I'm guessing a power output of somewhere in the 70-80mW range, which should be on par with some single-ended output from other respected portable amps.
Into 300 ohms, fully charged battery, its 94 mW or 5.3v RMS at the 1% THD point.
Rob
you have created a device that many will have to work so so so hard to compete with the mojo
so far best device i ever bought in my last 3 years
FYI - It didn't work for me with ZX2 and MoJo
i really need an ultra short quality micro usb- otg cable to go with my note 3 as the one i bought off ebay causes crackling in sound that is 10cm in length including the connectors
its so strange why no one can point to a high quality cable that is audiophile approved and is ultra short
