Been hearing a lot of things about battery issues, wondering if the way i’m using the mojo is detrimental to the battery life. I’m using it as a desktop dac so the battery is usually at full charge, I only plug the charger in when it’s in use and when it’s not in use there’s nothing plugged into it. I heard the problems with the battery mainly arise when leaving it plugged into power 24/7, so i’m hoping this is a good workaround. Anyone have any thoughts?
Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
- Thread starter Mython
DBaldock9
If you have a consistent time of day that you use your Mojo - you could get a programmable timer, and set it to turn off at the start of your listening session, and then turn on to charge approximately 6 or 8 hours later. To be more precise, you could time some listening sessions, and then set the timer to turn on at the time you've found the charge level to be at point where it needs to be recharged.
vlach
The Mojo gets plenty hot when in use and not charging. It gets even warmer when charging + playing at the same and only makes things worst for the battery.
I suggest doing one or the other but not both.
dakanao
- Jun 8, 2012
Would this also improve sound quality?Here's a slightly off-the-wall question -
Are the Volume balls simply the caps for a pair of push-button normally-open momentary switches?
If so, in a desktop application - I think it would be neat to replace the switches with a rotary encoder and a PIC processor, to simulate up & down clicks when a Volume knob is turned.
Good mine today , it was very good
But I'm curious, what is the function of two 3.5mm output?
gimmeheadroom
I really like the idea of the Chord technology, but not the esthetic of the products.
I agree but the problem is the magic balls are the UI. Without the colors you lose the ability to show sample rate and whether it's PCM or DSD.
gimmeheadroom
You and a friend can listen together if you have the same IEMs or headphones... to a point.
DBaldock9
Placing some translucent plastic over the Mojo's multi-color LEDs would allow the colors to be seen --- or a PIC / Arduino processor could probably be programmed to "read" the voltages / signals that are driving the LEDs, and then display the relevant information on a small screen.
DBaldock9
My idea is just a rethinking of the user interface - so it wouldn't affect the sound quality.
OkayYou and a friend can listen together if you have the same IEMs or headphones... to a point.
Btw, what is the indicator when the mojo is fully charged? Because it not shown anything when plugged..
Jupiterknight
When fully charged... then the light underneath the micro USB charger input is off! When still charging then active.Okay
Okay thanks for the informationWhen fully charged... then the light underneath the micro USB charger input is off! When still charging then active.
gimmeheadroom
I like your idea. That would be kinda cool.
I haven't seen many DACs that display sample rate and bit depth. Most seem to display only sample rate. One thing I like about my Brooklyn is that it displays both.
I'll probably be selling my Chord Mojo in a few months, the battery is almost dead and I don't want a battery powered device anymore.
jarnopp
- Nov 26, 2014
In that case, you can try removing the battery altogether and plugging in Mojo. It will run like that and may work just fine as an always powered, always on dac. Only issue is no remote control volume.
Are there any device that act like a chord poly for mojo? That can be controlled via smartphone. Want that function on poly but the price is very high for me. Thanks
Total: 48 (members: 0, guests: 48)
