I thought the LED in one of my volume balls died. But it was actually because of the low volume setting. Totally forgot about that.
If your battery is as dead as that, then you need to open the Mojo case, and visibly inspect the battery.For some time now, I've been having problems with my Mojo:
- It sometimes switches off by itself, which does not seem to be related to its workload - it can happen with my computer switched off and no USB signal (I know I should have switched the Mojo off when the computer is off);
- Most times, but not always, it makes rapid ticking noise right after switched on - that ticking noise is audible both in the headphones as well as coming right from the device itself.
These problems started a few months ago. Before that, the device had worked flawlessly for a few years. I have noticed no deterioration in sound quality. I am still using the same PSU as when I bought the device - a Belkin USB charger, rated at 5V, 2.1A and the PSU seems to work fine.
The battery is dead as a dodo - the moment I unplug the USB power cable, the device goes out. I don't want to pay for battery replacement, because it is expensive and there is no guarantee it will fix the problem.
Lately, I have been operating my Mojo in the Line Level mode (press both volume buttons upon switching the device on) and that has had no impact on the issues mentioned above - it still makes weird noises upon turning it on, and occasionally turns itself off. Also, ambient temperature does not seem to have an impact on it.
Here's something most Mojo owners don't know, but there's actually a noticable sound quality difference between the two 3.5mm headphone ports.
The left one has a lower impedance, and sounds slightly more detailed, with better bass slam and dynamics, but it sounds more edgy, less smooth on the impact of sounds.
The 3.5mm port to the right, has less bass slam, and slightly less detail and dynamic contrast, but sounds smoother. I prefer the right port, since it's bass slam and dynamics still is excellent, but the smoother less edgy sound wins me over.
This difference was consistent with a 16 ohm JVC-S400, 250 ohm Beyerdynamic DT150 and 250, and a 300 ohm Sennheiser HD650
I asked Rob Watts about this a while back, and he said that the right port has a slightly higher ohm due to a longer PCB trace.
Anybody compared Mojo and Dethonray DTR1 on sound?
On Erji i finding - R3 + Mojo - worst then DTR1, Iphone 5S + Mojo - much better than DTR1.
What you think?
Special interesting on stage, bass and dynamics.
TY.
I’ve just switched from an electrical (co-ax) Connection between my X-10Tii and the Mojo to a glass Toslink cable from Lifatec. It does make quite a difference. There is a marginal loss of “sharpness”, but a quieter, “blacker” background. The soundstage also seems a little wider. I was sceptical at first, having learned back in the 80s that “all optical digital connections are rubbish and to be avoided at all costs”. It does seem, however, that the quality of the optical interfaces has improved over the years. Oh, and the Lifatec is able to pass a DSD signal. I didn’t think that was supposed to be possible!
