unfortunately there still no mojo 2 on planning or production (confirmed by related distributor and dealer)
Thank you.
In my experience, its most likely cause by using standard usb audio driver by windows 10. Its not well compatible with Mojo.Hi every body and happy new year,
I'm a newbie here and tried to find a solution for my problem, but failed. Sorry if its addressed before, but I'm having occasional disturbing jitters in chord mojo accompanied by rapid flickering and flashing of lighted buttons. It's not a hum but rather a consecutive high pitch scratching type rapid noises.
This usually happens with DSD 128 or higher resolution music files. It doesn't happen much, and it's random. A specific track may play flawlessly now but encounters the problem the next session.Restarting mojo and/or changing usb port usually solves the problem, but temporarily. First I thought there's a problem with processing speed of my laptop which I usually use its usb port to feed my mojo. But I get the same problem with my Xiaomi Mi5s smartphone as well. I assumed a usb isolator might be of an answer, but do smartphones need a usb isolator too?
i see, thanks for ur referenceI have read so many posts about 'dealer inside information' for various Chord new products during the last six months, and they have all turned out to be false info, so I now treat such posts with a 'pinch of salt'.
What can be confirmed is that Chord have promised 'a parade of new products' this year, and that the full Chord team will be at Canjam New York . https://www.head-fi.org/threads/cho...fficial-thread.831345/page-1182#post-15396344
Some of us are assuming that means the 2Go will be the first of the parade at Canjam.
This post implies that a DAVE 2 will not feature https://www.head-fi.org/threads/watts-up.800264/page-108#post-15396995
But your guesses are as good as mine for the remainder of the parade.
Sorry for late answering,Does any other DAC exhibit this problem?
If it's a new Mojo, and it were me, I would be returning or claiming under warranty immediately.
I've used the latest drivers, Foobar2000, HQPlayer, JRiver MC on my laptop and HiBYMusic and FiiO Music on my android 8 phone. I get the same jitters/light flashing randomly with higher res files, and using Native DSD or DOP output makes no difference.Please tell us:
1) which Chord Mojo windows drivers are you using?
2) which app/program are you using for playback?
To me it looks like the Dsd file is being streamed out incorrectly. The Dsd file must be played out in Dsd-over-pcm (DOP) format.
Edit: May not be a driver or app problem if it is random.
As mentioned earlier, there's the same problem with my android phone.In my experience, its most likely cause by using standard usb audio driver by windows 10. Its not well compatible with Mojo.
http://chordmojo.com/support/#driver
u can try installing this. and reconnect ur mojo.
Email support@chordelectronics.co.uk and hopefully they will be able to propose a way forward.As mentioned earlier, there's the same problem with my android phone.
can anyone here let me know what addon i need to use my chord mojo with a ipod touch? , 2nd question : also how to use it with note 9 cell phone, links to products would also be nice, thanks
I remember there were quite a few owners who did post about using an iPod.can anyone here let me know what addon i need to use my chord mojo with a ipod touch? , 2nd question : also how to use it with note 9 cell phone, links to products would also be nice, thanks
The 'uses too much power' error message rings a bell in my mind.
