Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-12441933
Post #14,011 of 40,379
Mediahound
USA
USA
  then i do not understand your statement about lively sound with hard to drive phones....that's a mjolnir quality, not gungnir's...
you should hook up both dacs to the Mjolnir and make a comparation
That's is indeed the sound comparison when trying each DAC hooked up to the MJ2 amp. But the Mojo is not really designed to be used this way permanently so not really a good comparison.  It works in a pinch, but not an ideal setup.
post-12441954
Post #14,012 of 40,379
rkt31
wow, wow that's amazing. now I fully understand Rob watts comment that chord could charge lot higher if they would have put mojo into a large metal box . I very clearly asked about gumby vs mojo only for sq not for drivability of headphones . first of all the only way to compare both is to add an amp that would degrade transparency of mojo but I still feel purely for sq mojo will beat gumby ( even yggdrasil ) if attached to same external amp.
post-12441961
Post #14,013 of 40,379
Mojo ideas
John Franks
Sponsor: Chord Electronics
yes it can, go for Schiit YGGDRASIL @ $2,299, i don't know any desktop DAC can beat at this price range, not even at $1000 range.
I use Mojo as desktop Dac with my Genelecs everyday. By the way i choose Mojo over Audiolab MDAC, and Arcam irDac and some other desktop Dacs.
That's an interesting view point. How do those Dacs you mention actually measure when comparing actual specified test results to Mojo. A unit can only be called better if its specification really is!
post-12441974
Post #14,014 of 40,379
rkt31
I would say mojo and Hugo are first of all are dac, portability and headphone drive are added bonus due to clever and revolutionary design. I find no problem in desktop set up with Hugo . I have not tried mojo in desktop set up not due to any difficulty but it will require a 3.5mm stereo to rca adapter. Hugo is fed directly to benchmark ahb2 power amp in low gain mode . in low gain mode benchmark power amp increases the output about 3 times only so I get about about just below 10 watt with 8 ohm kef r300. this output is more than normal listening levels. only during movies I have to got 3volt of Hugo otherwise Hugo requires to go only upto 2 volts or so. that way I have one of the most transparent desktop set up for the money as benchmark is very highly rated for noise and thd. after getting mojo I don't need to remove Hugo from my desktop set up. Hugo will go only when I have enough funds for Dave.
post-12441977
Post #14,015 of 40,379
rkt31
in gumby's cost get two or more mojo. use one with desktop and other for portable. in yggy's price buy 6 mojo. use one in desktop , one for portable, one in car audio, one in the office , gift one each to better half and growing kid. lol.
post-12442165
Post #14,016 of 40,379
Mediahound
USA
USA
My Mojo setup is sorta funny:
Since my headphone cable is a balanced 4-pin XLR, I have an adapter to go to 1/4" and then another adapter to go from 1/4" to the Chord mini jack.
I could stand to eliminate one of these. Anyone know of a 4-pin XLR to mini jack adapter?
post-12442200
Post #14,017 of 40,379
bakieryigit
Chord Mojo + İOS 9.3 version working with  "Fiio L19 Cable" Without any issue.
worked with my iphone 6 plus and ipod touch 5.
Sample caps here;
İpod touch 5 + Chord Mojo + Fiio L19 Cable + Earsonics S-em9
post-12442204
Post #14,018 of 40,379
sheldaze
USA
USA
I bought my adapter from Amazon - cannot find the link for it at this moment. But here's one that might be even better suited to your needs:
http://www.amazon.com/Stereo-Female-Balanced-Adapter-Hi-end/dp/B011LRBIL0
post-12442224
Post #14,019 of 40,379
Mediahound
USA
USA
Sample caps here;
iOS 9.3 also working fine with the Apple Lighting to USB (CCK) adapter and the Mojo here.
post-12442225
Post #14,020 of 40,379
Mediahound
USA
USA
post-12442248
Post #14,021 of 40,379
rkt31
@you can buy a 3.5mm stereo to 2 rca adapter and then use 2 rca to xlr interconnects of short length. although rca to xlr adapter of neutric can also be used in place interconnects.
post-12442398
Post #14,024 of 40,379
Townyj
Has anyone compared the Bimby to the mojo. I am a bit bored of the mojos sound, yeah it sounds ok. Its a bit to polite and compressed. Wouldnt mind something a bit more lively to pair with a G109A.
post-12442401
Post #14,025 of 40,379
bavinck
Compressed? That's a first. What makes you feel it is compressed? What headphones are you using?
Users Who Are Viewing This Thread (Users: 1, Guests: 5)
