blueninjasix
- Mar 6, 2016
Schitt Eitr improved my sound with MojoWill a USB galvanic isolator improve the Mojo on my laptop? If so, what is the best, cheapest option?
My first thought is also thermal shutdown. I think there are 3 thermal protection circuits in the mojo, so potentially one of them has been activated. The first test would be to let the mojo cool down indoors, then try using it, and let us know if it now works ok.
That one is too expensive and too big, I'm looking for something USB sized.Schitt Eitr improved my sound with Mojo
Sounds strange to me, probably best to get an opinion from chord.My Mojo “flashes” alone when it’s turn off.
I mean, it suddently flashes (all three balls), while it’s turn off and when nothing it’s connected to it.
At the beginning I thought it was my imagination but today it’s happened again, just some seconds ago.
Is that normal??
Never noticed it myself.Will the Mojo sound "thin" or "less powerful" when it's battery is almost down (later orange or red status)?
There have been a few occasions when i have been so engrossed in the music, that it has come as a surprise when the mojo shut down with a depleted battery. I doubt that i would have been engrossed, if the music sounded thin.
It would be interesting to discover the thoughts of other owners.
Never heard that. It's good, then it's off!
unlike a torch
Hi, my mojo has this sound when the battery is full
https://photos.app.goo.gl/orgZh9h11SPV6Xy4A
Is it because one of the cell bad?
And also are there any replacement battery for Mojo aside from Chord?
I think that I am correct in saying that the current from a battery is cleaner than an AC current so should produce better sound and also I think that I am correct in saying that a LiPo battery like a Lithium ion will put out a near constant output right up until it dies. So I would say that the sound will not change. I have never heard it anyway.Will the Mojo sound "thin" or "less powerful" when it's battery is almost down (later orange or red status)?
It‘s normal for the Mojo to make some noise during charging and it is loudest just before the battery is completely charged.
Not a definitive answer I am afraid but I would have thought crackling would have been a more likely symptom of a mechanically faulty socket.Is it possible for one of the 3.5mm outputs to sound worse than the other, if I put my headphone jack too hard in/out of that output? Or will they still sound the same, even though I have inserted/pulled out the jack a bit hard a few times on 1 jack?
Because I have the feeling that the first 3.5mm output that I usually use (were I sometimes pulled/insterted my headphone cable hard into it) sounds a bit more grainy than the other 3.5mm output which I don't use as much.
But ofcourse, that could totally be placebo, but I'm wondering if there's a factual explanation that these 2 jacks will always sound the same, no matter how much tension is set on one of them.
