miketlse
- May 8, 2016
Not an issue, if you do not touch the volume balls again, because the Mojo will not remember the setting when you switch off.When you put the Mojo into line level it defaults to 3V. When and how can this be or become an issue?
Can be an issue if you touch the volume balls, because this takes the mojo out of line-out mode, and into normal mode, and the Mojo will remember the volume setting next time you switch on.
This has caught a few users out, if they had their iems plugged in, when they next switched the Mojo on - so be careful if you alternate between line-out and normal iem usage.
If 3V is too high for your preamp, then 4 presses of the -ve ball, will reduce the output to 1.9V, which is close to the 2V input sensitivity of some older AV kit.
