Hi Guys,
I have been using my iFi iCAN Micro SE for a couple weeks now. I have a problem, and I have no clue how to solve it, as I can't figure out which component is causing the problem. I THINK it is my computer, but I'm not sure. I am feeding the iCAN with a Chord Mojo, and when it was plugged in via USB to my Macbook Pro there was a very loud buzz/hum from 8 o'clock to 10'oclock on the volume knob. I then began connecting the Mojo to my Macbook Pro via Optical, and the buzz/hum went away. All is fine, or so I thought.
Now, I am getting electrical shocks when I touch the case of the iCAN, shocks when I touch the Mojo, and shocks from the Metal connectors on my headphones, when the headphones are plugged into the iFi. Also, if I plug the Mojo in via USB, you can see little sparks at the usb port as you plug it in, which makes me THINK it is my Macbook Pro that is the problem. This all happens whether or not the Macbook Pro is plugged in, or not plugged in, it makes no difference. The Mojo is battery powered, so I'm guessing it is not the Mojo, but I'm not sure.
I am going to cross post this in a couple threads, as I have no clue which component is causing the problem, and I don't want to fry my gear. Any help would be appreciated, I'm not an electrical engineer, and I'm so confused as to what is going on.
Note: The Macbook Pro, when plugged in, is using a 3 prong magsafe adapter. The iFi is plugged in via a 3 prong iPOWER.
